DTC P0506
mlatourette
Clearing the code fixes nothing, so if it keeps coming back, you need to find and fix the problem.
Clean the throttle body, check for vacuum leaks. If you have a scanner, are the "actual" verses "desired" idle speed with 75 rpms of each other?
Cleaned it all works great Thanks
