Belt System Squeak
Hello,
I have a pretty loud chirping noise when I start my truck when it is cold, especially when there was a heavy dew or rain.
I recently bought and swapped my old belt with a Goodyear Gatorback, but it didn't do anything to stop this squeaking.
When I first start, it is a constant and loud squeak. As it begins to warm up, the noise becomes gradually more irregular until it stops completely. From what I can tell this noise sounds more like metal vs metal rather than a worn out belt.
Also, I've noticed once when the noise was starting to go away I turned on the AC and it became a bit stronger.
I can't really pinpoint what is wrong, I have about a month left on my warranty.
I am thinking maybe the AC tensioner?
Any help will be greatly appreciated.
Chestah,
May be the water pump going bad. I had the same issues on a Delta 88. Changed belts, changed the fan, tightened pullies. Nothing did it. Then I found out it was the pump.
Might not be in your case, but wouldn't hurt to check it out.
I think the warranty I have covers anything oil touches and the water pump. I need to make sure before it's over with.
I just checked out my AC belt, and I think it may be a bit worn. I know it's definitely the original belt. What do you guys think?
This may sound redneck but with the engine running squirt some WD 40 on the fan belt. If it goes away, its' the belt.
I think if a pulley was going out, it wouldn't stop squeaking when the truck warmed up. Do you have your air conditioner or defroster turned on when you start the truck? If so, turn it off to eliminate the air conditioner.
Well I've got the 8100 V-8 and it drives me nuts. I did use WD-40 and belt conditioner to prove out the system. It shut up for a little bit...then it got worse. I've found the longer term fix is a dab of valve grinding compound...special thanks to a friend of mine who's a tech at a GMC dealership.
  • 11 months later...
My 1998 Yukon had a nasty squeel and after replacing the belt and tensioner a mechanic used a stethiscope and determined it was the alternator. We swapped the alternator with the High Output versionsince there are a lot of electrical devices in the Yukon. Problem solved.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
