2000 Silv won't start/turn over with key
Well, I went to pick up my daughter from school today, and when I came out to my 2000 ECSB 4x4 w/ 5.3 it wouldn't turn over. :D I tried taking the key out back in and trying again, and cycling the shift lever in and out of park several times. No Luck. Everything looked fine, so I used my remote start, and it started right up. When I got home, I shut the truck off and tried to start it with the key, same thing-no start. The Battery guage shows about 12.5 Volts, and when I turn the key, there's no voltage drop, and no clicking can be heard from under the hood.
I know with my remote dooor locks, that if you lock the truck with the remote, and then open the doors with the key and try to start it with the key, it won't start unless you press a bypass switch. I haven't locked the truck in awhile, so this isn't an issue. I haven't had any problems at all up until this incident. The battery is a few months old and the cables are good.
Any ideas? :D
ARRGGHHH!!!!
Well, after I posted my first entry, I went outside and did some troubleshooting. I checked the relay, fuses etc. I got it narrowed down to good power to the ignition switch, put it in "Start" and no power downstream. :D You're right. Bad ignition switch.
So, that leads me to my next question. I have to problem with my trucks maintenance, but have never changed this switch. Since I gather there are special tools etc. is it going to be better to take it in and have it done? (I Hate to think how badly I'm gonna get screwed). Or is it not too bad to change? Am I going to have to get a new key, or can they rekey the new switch?
OKay, I'm an idiot :D ...as a last resort, I went and pressed the "unlock" button on my key fob (even though the truck was already unlocked). The truck starts fine now. The remote start was already on the truck when I bought it, so I'm not really up to speed on all of what it does. I think I need to go get a new battery for it.
Thanks for the help anyway! :D
You're not an idiot, my remote start has a feature that disconnects the key switch to prevent starter grinding and also functions as a starter kill when the doors are locked or alarm is triggered. The on-board relay sticks sometimes and will not allow me to start the engine with the key......I've since disconnected this feature :P:smash::D
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
