Do I have a trailer tow pkg??
Hello all. I just bought a 2004 Chevy 2500HD Ext.Cab 4X4 from a dealer. He told me that it had a trailer tow pkg on it. There is a hitch in back. I just wanted to verify that I did have this pkg. I looked up my RPO codes online and saw nothing that said trailer tow pkg. A few codes did say engine oil cooler and transmission cooler and a 105amp generator. Don't trailer tow pkgs also come with a bigger battery and bigger altenator? Is it safe to say that I do or not??
Bigger alternator comes with the snowplow package. If you have the engine cooler and tranny cooler. Then you have the tow package.
I don't have the Z82 code nor do I have the 7 pin receiver as shown in the picture, I guess I don't have the pkg then. I'm not sure why there's a hitch on there with no type of receiver, where do you plug in the trailer at???? My boat trailer has the 7 pin plug. I guess I probably need to take it to a trailer place and have a receiver put in???? I'm a little confused now. :D
If I understand right you have a aftermarket trailer hitch but no trailer electrical plug. I think if you look by the spare tire there should be a pigtail or a tap in near there so you can add a trailer electrical plug. Since you don't have the package and if your boat is heavy I'd add a trans cooler as a minimum.
Thanks guys, I got it now. I looked up underneath by the spare tire and there was a 4pin wire hanging up there. Looks like the previous owner put on an aftermarket hitch and also wiring. My RPO codes say that the truck has a trans cooler and engine oil cooler and 105 amp generator. But I didn't see the code for trailer provisions (Z82) which I assume is the trailer tow pkg.
The factory trailering package does not include a larger battery or higher capacity alternator.
DEWFPO
Yes, I do have the tow/haul button on the gear shifter.  :)
I thought they ALL wome with tow/haul, with or without the tow pkg.
DEWFPO
DEWFPO
They do.
A factory tow package equipped 2500 or 3500 series will have a factory installed transmission oil temperature gauge in the cluster (for auto transmission), without the tow package, you do not get the gauge.
This is the easiest way to verify if you have the factory tow package.
That'd be goofy a 2500 with out a tow package standard. What do they think, we buy these big trucks to go to the grocery store?
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
