'07 Yukon Denali
Greetings to you All,
Just wanted to say hello and give the '07 Denali Yukon a huge thumbs up. I was torn between the Hummer H2 and shorty Denali but the engine is what won me over to the Denali. I use to have the big Triton motor found in the Eddie Bauer Expedition and it was fairly good on the overdrive/passing gearing but after years of headaches I finally came back to a GM product.
This 6.2 L they have in this truck is simply awesome. Power and then some head whipping more if needed. The first thing that came to mind was that if this motor was in something very much lighter it would be insanely quick and nimble. The six speed tranny is smooth as silk and the exhaust has that distinctive undertone, stating that something other then the norm resides under the hood. The first time I looked at the motor was after a test drive and was speechless at the small size. I was expecting something massive that fit wheelwell to wheelwell, something I was fimiliar with in the Ford.
So far the truck is great. I haven't had any problems the last two weeks I've owned it except for a sensor that went out. The tech who was shutting the hood did leave a small dimple from slamming it down so hard but the dealer is going to have the Dent Wizard guys make it right. Mine is a black on black one with all the whistles so I'm sure you all know what it looks like. I'll post some pic's once I get a chance to detail to Dana 16's perfect recipe for keeping black looking good. The worst part is they give you three months of XM satalite Radio, I don't think I will ever go back!
Hopefully I can contribute to the forums in some way and look forward to reading all the threads. Later, Mike.
Congrats on the new rig. I wish i had a shorty, I've racked up almost 20,000miles on my dad's 07 denali xL, and i still can't believe the power of the6.2. I very seldom have to get it above 3,000rpm for anything, but tonight i decided to burn some gas, and i'm still amazed at the oomph it has. Me and the g/f were going 80 on an "on ramp" getting on the interstate and hadn't made it on the interstate yet before she was making me back off of it. They also get great mpg for a rig that's so big. I just made a 1200mile trip to NM, and averaged 17.8, and that was going 80mph minimum. :loser: The 6sp with 3.42 is a great combo imo. Wish i could have gotten it in my new sierra but i had to settle for the 6.0 with 4.10's which i'm sure will be pretty spunky, but i doubt the combination will produce the same mpg with the 4sp, but there's hope.
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
