Someone Photo Black flares on my truck
vctbmcam
Need help photoshoping black fender flares on my rig. I am torn over which ones to buy either black or just get matched color. I am leaning towards the black because everyone has colormatched on a white rig. Any help would be much apprec. Thanks
Well, ya didn't say what kind of flares you're wanting.
Here is your truck with a flare/running board combo. They're kind more gray looking 'cause black look more like a shadow.
If ya want some other kind of flares, leave a link or something of what you are interested in seeing.
OK then, how's this .....
And as I've said before, I don't claim to be the sharpest pencil in the desk at this stuff, but I try.
P.S. I think the black looks good on a white truck :D
Thanks Travis.
I just used the pics from the link. They were at a little bit different angle, but they didn't turn out too bad.
With the black bedrails, hood deflector and tinted windows, they go with the truck pretty good.
Good luck on whatever ya choose to do.
I am going with the black. They match the cover, windows, handles, etc. and they are a bit different than you normally see. thanks have a good one.
  • 1 month later...
so you like the black on white do ya? check out my 20s
anyone want to shave my door handles and gas tank door. and get some clear corners on there?
I think the black wheels look great on your rig. I am thinking about use the blck dupli-color whell paint on my stock wheels and if it looks like s*$%, I will get some new wheels.
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
