antifreeze drain plugs
my98z71
I would like to flush my antifreeze but when I looked under the truck I didn't see the plugs. I think there are supposed to be 2 drain plugs on a 98 z71. Can you give me a pointer on where to look for the plugs? Thanks
IF it is the same as my 97 you have to remove the knock sensor on the right side by the starter. Left side is a square plug behind the motor mount.
