Defective coolant temp sensor
I recently installed a set of Gibson headers to my 2000 K3500 7.4 Liter. The coolant temp sensor was damaged then replaced. Now the temp gauge reads at the mark between 100-210. Assuming this is around 155, the truck
has never ran this cool. Always 180-185. There is a hypertech 180 thermostat installed. Should the temp sensor
be the first place to start to diagnose this?
First thing to check would be that the ground straps all got put back and are tight and clean. A poorly grounded engine is a likely cause of this problem.
The only way that engine will run that cold is if the thermostat is stuck open. Start the engine and see if the upper raditor hose starts heating up right away. It should remain cool until the thermostat opens for the first time.
If it's neither make sure you got the right sensor, likely you did. There's always the gauge or instrument cluster that could be defective. But seeing as it occured during the header job I'd start under there.
Vernon
I would start by scanning the coolant temp on a scanner and find out what the PCM is reading and go frm there the guage is just an indicator and could be wrong. The scan tool will do a digital readout.
did you ever resolve this issue i have had the same problem about 155 with a 195 thermostat my truck is also a a 2000 7.4 k2500
