adjusting valves
Are the valves adjustable on a 97 5.7 . I've got a tick somewhere and after I change the donut gaskets on the exhaust I figured checking for a rocker arm nut that maybe backed off alittle.
I am pretty sure that they are, I have had the valve covers off of my 97 and if i remember correctly they are adjustable, however I believe the NBS trucks with the 5.3 s are no adjustable.
No the lifters are rollers and there is no adjustment. There is a collar on the rocker stud and the nut is tightened down tight.
if you have the LS series motor I believe their is no adjustment. But be sure pop the valve cover and look at the rocker arm. if it does not have an adjustment at the oiling hole for the push rod the only adjustment is the rocker arm nuts and are torqued to manuf. specs.
comp cam and harland sharp make adjustable 1.7:1 roller rockers and are a bit pricy
I hope this helps
Its a 97 vortec in a yukon, I'm hoping it's something simple like the exhaust donut or a loose rocker , If not ,I don't know where to look next, It's a tick that gets louder the more load you put on the motor. any help appreciated
From the Helm's Manual:
With the Engine in the number 1 firing position, adjust the exhaust valves for cylinders number 1, 3, 4, and 8 and the intake valves for cylinders number 1, 2, 5, and 7.
Turn the valve rocker arm nut counter clockwise until the valve lash is felt in the valve pushrod.
Turn the rocker arm nut clockwise until all of the valve lash is removed (zero valve lash).
Zero valve lash can be felt by moving the valve pushrod up and down between your thumb and forefinger until there is no more up and down movement of the valve pushrod.
When all the valve lash is removed, then turn the valve rocker arm nut clockwise 1 additional turn (360 degrees).
With the engine in the number 6 firing position, adjust the exhaust valves for cylinders number 2, 5, 6, and 7 and the intake valves for cylinders number 3, 4, 6, and 8.
Follow the same steps as above.
Make sure the engine is cold, I like to do mine first time in the morning after the engine has sat all night. My old enging began to have the annoying chevy clicking until I followed these procedures and the noise went away!!!!!
