Never starts on first try
My truck is now six years old, has 50k miles, and never starts on the first turn of the key. It did when it was new and for about two years. There after it took two tries to start the truck. Recently it was taking three cranks so I decided to get a knew battery. The battery helped but the truck still doesn't want to start on the first crank. What can I do to get it to fire right up ?
change the........i dont now what you call it
it is the thing that make the car starts
not the one you but the key in it
you can see it under the car in the right sid of the engine
Take it to autozone or advance auto parts and get the computer scanned, I'm pretty sure its free. If it cranks fine the starter should be good, so it might be a fuel problem.
Could be an ignition problem too. Id check all the fuel lines/pump, and also all the ignition components. Before you start it for the first time one day, pop off a spark plug cap and have someone else crank it over to see if your getting sparks on the first attempt to start. Im pretty sure you gotta stick a screw driver tip inside the cap so it sparks, Ive only seen this a few times, maybe someone else can chime in. **I'm not liable for any bodily damage** :shakehead:
Definitely check your fuel pressure. It is even harder to start when it is cold outside?
I had similar issues before I changed my fuel pump.
It's called a 'starter' bro. :shakehead:
The starter still seems to be working well enough. The truck starts up consistently on the second turn of the key. I was just hoping the new battery would get it to start right up on the first try.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
