Stupid Question?
I have a GMT-900 w/ the 5300.
The description in the brochure says "4 speed transmission w/ overdrive". My buddy is telling me that my truck should be a 5 speed then since it says "w/ overdrive".
I'm not feeling 5 speeds when I drive, and wasn't aware GM made a 5 speed. So I have do have a 4 speed...right?
Warned ya it was a stupid question.
Also the 6000 specs just says "4 speed". Doesn't mention overdrive.
Thanks,
Corey :loser:
It used to be a big selling point a long time ago (probably when dinosaurs roamed the earth...lol) that a transmission came with overdrive when they didn't commonly come with them.
Just assume these days that everything has overdrive even if it's not mentioned. Some transmissions (I think GM's new 6 speed) even have 2 overdrive gears (5th and 6th gear).
IIRC, "overdrive" is any gear ratio less than 1, like 0.7 for 4th gear in our 4L60s and 4L70s.
1st - 3.06
2nd - 1.63
3rd - 1.00
4th - 0.7
In the 6L90 6-speeds, 5th and 6th gear are less than 1.
1st -4.03
2nd - 2.36
3rd - 1.53
4th - 1.15
5th - 0.85
6th - 0.67
