Elevator Jokes
Combatvet0311
Position yourself where he's standing behind you and start mumbling a two-way conversation to yourself.
"you shouldn't have killed that guy you know"
"I know, but he wouldn't quit staring at the back of my head"
  • Grimace painfully while smacking your forehead and muttering: "Shut up, d**n it, all of you just shut UP!"
  • Crack open your briefcase or purse, and while peering inside ask: "Got enough air in there?"
  • Greet everyone getting on the elevator with a warm handshake and ask them to call you Admiral.
  • Frown and mutter "Gotta go...Gotta go..." then sigh and say "Oops!"
  • Draw a little square on the floor with chalk and inform the other passengers that this is your "personal space."
  • As a passenger enters, in a Scottish accent announce "Ready to beam you up Captain"
Immidiately after eye contact scream at the top of your lungs for about 1 second, then act completely normal.
:thumbs::sigh:
My elevator jokes are a little on the mean side.... and they don't have speaking parts.
People tend to not like it when you're on the top floor jumping up and down in it as they're trying to get off.
  • 2 months later...
Whats the funniest thing you guys can think to say to a stranger as the door opens and they start to step onto an elevator you're already riding in?
pace back and forth real frantic like and when they go to get off tell them that they shouldn't be contaminated
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
