00 Silverado heater problem
I have a 2000 Silverado and I can't get any heat out of the heater. The blower blows well, but nothing but cold air comes out. I tried rotating the control from AC (blue) to Heat(RED) and no changes. I checked both of the heater hoses going into and out of the core, both are hot, so I am thinking the hot water is making it to the heater core. I have read the manuals and see it mention "a heater control valve is shut" but I can't find any heater control valve anywhere.
I am wondering is there a heater control valve that might be shut which is by-passing my heater core? If it does have a heater control valve where is it? If not, could the vents be locked in the open air position and not able to switch to pick up the heat from the heater core?
A few months ago, the heater was stuck on (I couldn't get the heat to shut off no matter which position I put the heater control switch too). The only way I could get the heat to stop was to shut the truck off (remove coolant flow). Then it would switch to cold air. Anyone have an answer for this one?
Ken
Ken
I have also experianced this, and I will be watching this post for an answer.
KEN..........Most likely you air mix door is stuck or not moving.
Can you hear it move or hear any noise coming from the
heater duct work? Turn the control knob while down on the
passenger side floor. Listen................
Gone are the external water valves. Gm had them under the
hood in the heater hose lines near the fire wall. I guess if
you don't see one.....................
Check out this thread:
http://www.fullsizechevy.com/forums/archiv...p/t-155993.html
Don't forget to do a search on this...I did quite a few posts !.................geo
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
