Vibrations while braking
I have an 06 EC 1500 rear drums. Almost everytime i hit the brakes the front end seems to bounce, i assumed it was the front rotors so i replaced them with new pads. this didnt seem to help anything any ideas on what direction i should go from here i tried searching and found other posts that all had diffrent ideas. i found one about beam shake coud this be the problem
1. Make 100% sure that your front brake rotors are perfectly "true"
If they are new-go to a parts house and get them machined or replaced with another set.
2. If your brakes still pulsate, take off the rear drums and have those machined also.
You have to ge step-by-step with brakes. 90% of the time, a pulsation is due to the front rotors being out-of-round.
If you are still under factory warranty, drop the truck off at your dealer. See if they will cover brakes. Most dealers will.
after getting the new ones took them off and had them checked they were still good i guess i will try the rears tomorrow it seems like it is coming from the front
typical drum brakes!!!!
  • 5 weeks later...
had he rear drums checked they were good. Put a set of 2" shackels on th rear this seemed to help some. took to local garage they did a check and cameup with nothing.
started to notic a clunking noise from the front drivers side. when you push on the back of the wheel it makes a popping noise. could this be related or something new. i am thinking this is wheel bearing or could it be the steering shaft that everyone is talking about
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
