Cold weather starting problem - Fuel Pressure Readings
2002 silverado 1500 with 5.3 gas engine
Problem: doesn't want to start in cold weather - intermittent but colder is worse
New Parts so far: Fuel Filter, Fuel Pressure Regulator and Air filter.
Parts checked and cleaned: Fuel Pump Relay, all fuses, OBD pending codes, IAC and throttle body.
Fuel pressure readings (two tests in 40 degree weather, listed in order):
cold before starting: 54 and 57 PSI
running: 49 and 52
shutoff: 48 both times
5 minutes after shutoff: climbed to 58 and stayed both times
retested with gas cap on and off - no change
After starting: runs like a champ at all times.
Owner: frustrated.
Not to rub it in...I'm a warm weather so I don't know too much about cold start, but a few ideas.
To start you need fuel, air, spark
condensation in the fuel?
ice on the air filter/inlet?
older plug wire, ice condensation shorting to ground?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
