which the right ecm/pcm
mightybg
1991 2500 4x4, 5.7l "K" built in canada.
what is the right ecm /pcm for my truck. I unpluggeed the knock sensor to check if it is causing me problems, drov ethe truck and never got a check engin light or stored code 43. I want to replace the ecm/pcm and found it had a rebuilt 16147060 in it. it says rebuilt by gm on it I don;'t think it would come of the assembly line with a rebuilt computer,so i was wondering, is that the right pcm? my trucks knock sensor goes straight to the ecm/pcm, no knock sensor nodule on it(dark blue wire to computer). thanks for any help.
The part number you gave has changed see info below and match your option codes to see if it is the right one. The new part number is the first number listed below.
88999179 CK2,3 5.7K (L05), 4.3Z (LB4), 4-SPD A/TRANS (MT1), 11000 LB GVWR (C7E), 10000 GVWR (C7A), 12000 GVWR (C7L), 9600 GVWR (C6Y), 15000 GVWR (C5B), 9000 GVWR (C6U), GUAM (CW6), 8600 GVWR (C6P
