Going to Shoot My Poor 4.3
DirtyDave
I have a problem. There's a S&W 500S on my kitchen table and a 4.3 in my garage that is driving me nuts.
I'll try to give you as much info as I possibly can. I have a 1998 GMC Sonoma 4x4 with a 4.3 and a five-speed. It has a hollowed out cat and a Dynomax cat-back exhaust system. It's got 100,300 miles on it.
I'm having a couple of problems. Well, let me step back a little. Last Sunday night I went out the garage to start my truck to go to the store. It cranked but wouldn't start. I could hear the pump coming on and the engine was cranking as it should have been. I stuck a screwdriver in the coil wire and the spark was orange in color and not really snapping. I replaced the coil the next night and the truck started right up and it ran great all week. Sweet, right? Not so much.
Yesterday morning (something about Sundays...) I went to breakfast and the d**n thing wouldn't start. Same condition. It cranked like hell, I could hear the pump, no start. Fortunately, I had gone with some friends. We ran some errands, came back and the thing started right up. This time though, the idle was a little screwy. It would idle above 1000rpm, which it never does when it's warm. If I "blipped" the throttle, it would settle right down to ~600 rpm. The truck was surging and back firing occasionally. But, if I put it to the floor, the thing would take right off and leave two black marks, as I'm accustomed too.
Here's what I've done: last fall I replaced the plugs with AC Delco platinums, the cap, rotor, plug wires and fuel filter. I replaced the coil last week. Today I installed a new ingnition module. The truck started and ran, but it still had the high idle and it felt almost as though it was missing under part throttle. There was no backfiring or popping, but it definitely was not running well. Again, if I gave it the floorboard, it ran like a champ.
I was worried about fuel pressure, but after the no start, I pulled the plugs out and they were pretty soaked with fuel (I had cranked it several times), so I'm guessing I've got enough pressure to open the injectors. I know these things need at least 52 psi or so. I don't think it's bad gas because I've bought gas since the problem started.
Any suggestions? I need this thing to remain the dead solid, reliable truck that it has been for its first 100,000 miles. Thanks for your help.
Pull the dipstick and smell the oil, if it smells of gas you probably have a leaking fuel pressure regulator. if you pull the top of the intake and one side is clean its the regualtor. From GM you have to buy the whole injector assem, but I have heard that the aftermarket now sells just the regulator.
GM sells just the regulator now, too (and for less than aftermarket!). I purchased one and will install it tonight. I'll let everyone know how it turns out.
Fuel pressure regulator seems to have taken care of it. I had to buy a plenum gasket kit.
It still idles a little high and has a slight stumble around 2000 rpm under light load. I'm guessing this is a TPS issue though.
So, all is well and I don't have to but a 400 grain round through my block.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
