2008 Ford Diesel Recall Video
Silverado4x4
From an article about the recall...
The software upgrade will reset the powertrain control module on the Ford trucks. In cases where the system detects unusually high temperatures in the diesel particulate filter, the control module will power down the vehicle.
Shutting down the vehicle if the particulate filter gets too hot? That doesn't seem like a very good fix to me. More like a band aid over the real problem.
http://money.cnn.com/2007/03/21/news/compa....reut/index.htm
I don't know if it was the audio on that video or what, but the knock on that engine sounded awful. Can you imagine driving down the freeway with flames shooting out of the tailpipe. I agree, shuting down the engine due to high particulate filter temps is a bandage. They'll probably figure out something better for the next model year (that's how the system works). I take it this particulate filter is to address the increased emissions regulations (i.e. this is the first model year in which this particulate filter is standard equipment).
I want that on my truck, just for those stupid little ricers with the melon shooter exhaust.
Burn em all and dance on their ashes!! :)
That's what the ticking reminds me of, if you slow it down, it'd be like those 70's-ish sound effects from the Six Million Dollar Man when he went to jump or punch, ha.
Yup...that's what people want. Spend $40,000+ on a truck that turns itself while your hauling a load down the freeway. That's a heck of a sale's pitch, 'yeah its a great truck, just watch out for flames outta the tailpipe, and when you work the engine hard it will turn itself off.'
-Jay
