1969 Camaro Rs
FYI: please E-MAIL me if you are interested, if you respond in this thread or my PM, it may be a while before I respond)
1969 Camaro RS, asking 29,500
Less than 4K miles on engine and trans
Beautiful, deeeeeep bright red paint and stripes(painted on under clearcoat, of course), get plenty of comments, the mods were done in a manner to keep an original appearance.
1969 Chevy Camaro RS
350, 3 speed auto
engine and transmission rebuilt at 69,850
400 crank
Bored .030 over
electric fan
Balanced
CompCams Magnum 280H cam (complete kit); adv. Duration 280*, lift .480”
true dual exhaust,, FLO-PRO mufflers
Hardened valves/seats
ProTopline 23* PRO LIGHTNING heads
Performance (hyper Teutonic?) Pistons
Edelbrock Performer RPM Air Gap intake
Holley 750 Carburetor
Holley High Performance Fuel Pump
Stainless steel braided engine bay fuel lines
ARP rod and head bolts
2.73 10-bolt
Hooker headers
Correct SS badges all around
Transmission “rebuilt to handle power” w/2500 RPM stall converter
MSD 8.5MM wires
Alpine 6-Disc CD changer
Alpine deck
K&N Filter
Custom Infinity and Blaupunkt speaker system
Factory console gauge cluster
Factory Functional Cowl Induction
New Accel Shorty plugs
Org rear axle: Rear axle: BP 0828G2
The engine pics turned out bad, the compartment looks a lot better(and newer) than this.
Wow. That is a gorgeous car. Wow. Why are you selling it?
I've decided the money would be more useful right now than the car.
AKA: getting married.
Believe it or not, she wants me to keep it, But I could(excuse the technical terms) lower monthly "outgo" (as opposed to income) by "a bunch".
And she's agreed I can get something really cool again in a few years once were "settled in"(she starts her own career, and we eradicate the student loans)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
