Winner...winner...chicken Dinner!
Glad to be part of the forum. I will be in the market for a new truck in April of '08..right now I'm doing as much research as I can- and I have found that forums like this one are the best source of information without seeing gum chewing, sunglass wearing, tassled loafered, argyle sock wearing salesman.
2 more an i am done
Welcome - Lot's to learn here. Check out all the auto mag sites as well. They love the Silverado!
