Indy 500
RyanbabZ71
Thought I would get into the spirit for the race this yr. My impala needed a new front plate and I came across this
I should have gotten tix the race is not going to be televised here which sucks Ill have to turn on the radio and listen to it.
I can't see the picture.
Like HyperBuzzin mentioned, it's one of those 'GM Staff' only pictures.....only GM Staff (aka mods) can see. :driving:
Like I said I didn't think we had that option. But I guess you guys are proving towards the contrary.....
Does the error message actually say that it's a staff only pic?
I'm being 100% honest here with you guys, I didn't think we had "Moderator only" pics option....
i can see that one just fine. it just seems that when you all post them as attachments is when i can't view them. just gotta love modern technology. :fume:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
