Rear A/c Drip Pan Leaking
This is a warning to all Suburban and Yukon/XL owners. This might have been already brought up and worked out with a fix, but a quick search and I didn't find much so... here goes...
The rear A/C has a drip point in the rear up under the truck to the rear of the passenger side. There is a nipple that extends from the truck and is pinched by design. This is a great design to let water come out and keep dirt out. However, mine became clogged.
I had begun to smell a mildew smell in the truck so I thought maybe the kids spilled a drink so I had the carpet professionally shampooed and cleaned. This helped for about a few days. The smell eventually came back. I was vacuuming the truck one afternoon and was getting the food remnants from the rear clamping points for the 3rd row and lifted the carpet to get a better angle on the mess. To my surprise there was water pooled in there too. I felt a bit more and holy sh!t the pad was soaked.
I pulled off the interior panels, cut and removed the pad as much as possible to dry and let the truck air out for a day. It dried and no harm was done thankfully (meaning no mold). The drip pan is on the passenger side in the rear right above the exterior nipple (obviously). It is a sealed unit so it can't be opened and cleaned.
Anyhow, moral of the story is to check that nipple at every gas fill up. I tweaked it the other day and a lot came out meaning it was blocked again, but not as much as first time. Check it often so I'm the only one with this experience. :D
that nipple. I tweaked it the other day
Haha, I'm now recalling a story I heard about Jennifer Lopez having a person on staff just to do that for her. But enough of my useless info.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
