Adding Electric Fans To 04 Burb
pastorscott
I would like to replace my belt driven fan on my 04 burb with the 05 electric fan system. Whats envolved with such a change ? Would the 05 system bolt up to my o4
Scott
If it has the 34" rad then get a set of the e-fans , and wireing harness for a 05 1/2 ton drop in use pins 33 and 42 on the PCM , have PCM programed for fans .
If 27" use LS1 fans and I have a wireing harness diagram that will work for them as well , still use pin 33 and 42 on PCM .
Also need a 145 amp alternator and 1/2" longer belt .
I installed factory fans on my 05 1500 HD 6.0, with nelson fan relay harness, it only uses pin 42, is 33 for a/c signal? As nelson harness has you jump off a/c clutch which turns right fan on at high speed, I would rather
have both fans on at medium speed as it appears right fan is running at high speed going down highway and
I do not think this is the best way to run fans. If I had the option I would like to run fans to keep a/c high pressure in the 250 pound range is there anyway to do this?
Thanks for any info.
  • 3 weeks later...
Check out SPAL USA
I been using this for about 9 months and works great. Fan comes on slow and then when you want full blast it will do it automatically or you can manually.. I got it off Ebay for 65 bucks and a relay box too.. let me know if you want me to find the SPAL dealer on Ebay for you..
These people are good also , Painless
Be careful with large fans and no fuses inline to the relays (need at least 40amp for fans and 10amp for power source) can cause major damage .
Scott
I believe Flex a lite offers a kit.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
