Help With 3" Body Lift On 01 1500
like it says i have a 3" body lift on my 01 1500 ... anyone else who has these could you put a few pics of yours up with bigger tires ... i have 265 on now but i'd like to go a little bigger ... just not sure what size to go to. Thanks! -Mat
nobody has a pic with a body lift?
you should be good to run a 33" tire, you might have to trim the lower valence on the front bumper though. if you do jump up to that you might consider some gears too, but the real question is why the hell would you do a body over a suspension lift anyway?
because i actually did it a year ago and really liked the look of the HD so with a body lift it looks the same. i think it looks good ... i'm just wondering more about what it looks like with different sizes of tires on it ... i thought at least a few people would have just a body lift
Had 33's on mine for about 100k miles then made the switch to 285's Both rubbed ever so slightly, but i have 10" rims and the T-bars are as low as it was new. Lots of rake. Body lift is way to go for me cheap, can be reversed or installed in a few hrs. i know of two people who have 33's with stock suspension, no body lift, not even torsion bar lift, and no rubbing, but they both have stock rims. sorry i dont have any pics but i know theres one in a guys sig, he posts alot, but i cant think of his handle. tan ext cab 99-02 body style.
I was able to fit 285-75-16's (33x11.50x16) on my stock rims with no rubbing at all. I have 2000 1500 ECSB 4x4 and no rubbing at all not even at full lock and a little body roll. I did however add the ford keys to get the truck mostly level. There is only a 1" difference between the front and back and it looks really good and still rides nice, IMO it actually rides a little nicer.
how hard is it to put those ford keys in? how much do they cost? do you have any pics of your truck?
my buddy has stock rims on an all stock 2002 silverado reg cab with 33" BFG all terrains and didnt lift it at all and no rubbing. I went out bogging with him and no rubbing. It just looks funny because the tires take up the whole wheel well LOL but I dont think you can go any bigger stock hight with 33"s
i was think 285/75 16's but i'm looking more for pictures of someone with those on their ride so i can see what it looks like
I have a pic on my profie here. I just dont know how to tell youi to get to it. Click on my username or somethin cause it's on there. Im runnin 285/75/16's. Good luck! oph and, of iu cant find it, there is some pic's on my myspace. www.myspace.com/bradilacpimpin
i couldnt find your pics
you should be able to now.
i clicked on your name and then on your gallery but it says theres nothin in there?
ya just try the myspace, i know theres a few in there, I approved you
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
