Rf Modulator Has Really Low Volume Output..help..
Hey guys....after spending about three weeks researching the d**n things, I finally picked up a Scosche FMMOD01 RF Modulator so that I can play my Creative Zen M in my '07 Classic Sierra. I have the in-dash 6-cd changer (Bose) with the steering wheel controls.
Problem: After installing the modulator (had to cut the antenna cable and create direct connect splice due to incompatible connectors) I find that the sound is fairly clear from my mp3 player, BUT much lower volume than regular fm or cd.
My connections are good (ie no shorts), but I have to turn up my amp volume to 3/4 to get decent sound with the player at 50-75% of max volume (anything over that causes clipping and distortion).
Question: Is this a common problem with these modulators? The only other option is line in, but I have no inputs on the back. My buddy (service advisor) faxed me the service schematics for the unit, but I'm not sure where to splice into for my line inputs.
I have found a link to this harness from one of wingnut's posts, but is it the only other alternative? The d**n thing costs about $100 with shipping......http://www.jpcustoms.com/store/customer/product.php?productid=16391&cat=306&page=1
Your experienced suggestions are welcomed. Thanks.
Get a PAC adapter. I had one of these on my truck to run the volume for my dvd player:
PAC AAIGM12
PAC AAIGM12
Thanks for your reply.....the only problem is that my unitn HAS the XM radio built-in, and the 6-CD changer built in as well.....the info I found indicates that it won't work. At least that's how I'm reading it......
Sorry you're not getting much help...Most folks don't do much with the modulators these days.
I used one a few years back, and it was so horrible (soundwise), I ripped it out in less than a week.
I use a USA Spec unit, the radio thinks it has a remote CD player as well as the indash 6.
I have plugged mine into the XM side as it has better bass then the cd changer side. Maybe look into that unit. And it will work with XM.
http://www.oemautosound.com/pm-239-11-chev...ce-pa11-gm.aspx
http://www.usaspec.com/ipod.html
Your right on the money with the RF... they lose sound quality and volume! Mine sounds crystal clear and has no hissing and higher volume.
Just reporting back, guys.....I tried the scoche modulator, and I was impressed with the quality.....but the volume was very low, and when I maxed out my mp3 player volume, the sound was badly distorted. I ripped it out, and tried a Belkin Tunecast II FM Transmitter from Walmart for $30. Very good volume level, and very good quality sound......I would recommend it so far.....!!
I just thought I'd share some results, guys!
That's the one I started off with, then went to the iTrip. They work fine as long as there are no local radio stations close to the one your lock on. The problem I had was around town it was fine, then go into the city and it would fade in and out.
What kind of MP3 player are you running? Maybe add a RCA input instead? You can get one of the 1/8 jack split to RCA and run it direct.
ZR.....the thing I like about this unit is that you can change the frequency through the entire spectrum.....I haven't had any problems around town with it. I'm using a Creative Vision M unit.....the 1/8 jack plugs straight into it.
    Brandon 29
    Brandon 29
  • Who's Online   4 Members, 0 Anonymous, 595 Guests (See full list)
