Diy Oil Change On Nbs Sierra
Can anyone help me locate the oil drain plug on the NBS? I know generally where to look but nothing is obviously the oil drain plug. Ive never done this before so I could use a little guidance. A photo would besuper helpful. Thanks in advance.
  • 4 months later...
You know I use to DIY it and then I came to find.....It's cleaner, faster, and costs less to take it to the GM oil change shop at the dealer. They use Mobil 1 and it's done in about 10 mins and my driveway is clean and so am I. About $33.00 and I'm done.
The oil alone almost costs me that at Walmart...
It's up to you....
locate the oil pan infront of the bell housing on the transmission, the drain plug is pointing toward the passenger on the side of the oil pan and you can see a buldge in the pan that leads to the plug. hope that helps
It's up to you....
I would be glad to pay to have it done for only $33...around here you can't hardly get an oil change using regular oil for that price!
it costs about 70$ to get our kind of truck oil changed in my town (for mobil 1) ...
Thats nuts. I spend $57.00 on 6 quarts of Royal Purple and a K&N Oil filter or $50.00 if I use a Napa gold filter
  • 1 month later...
OK first off idk about the dealership automaticly replacing your oil with mobil 1 unless you ask for it and they straight up tell you yes we are putting mobil 1 on your vehicle at the dealership i work at we charge $9.95 for a basic oil change which we use a bulk of some GM oil trust me not mobil 1...dont get me wrong its still alright but yeah not mobil 1....i think we charge around $60 for are premium oil changes which is mobil 1........but yeah about your oil drain plug it is on the lower part of your engine oil pan and is either a 13mm or a 15mm depending on your vehicle and its either facing towards the back of your truck or facing the passangers side.....you should notice it pretty easy its the only thing on the lower part of your oil pan thet can be unbolted
Sorry, I can't help on the location of your plug, but have a comment on the price of an oil change.
I change my own oil and filter for around $20. I just use regular dino Valvoline 5w-30 and usually an A/C Delco filter, but I've also used Pureolators and the Advance Auto Parts brand and I change them around every 3,000 miles. Plus I grease all the fittings and just do general inspection of everything and it usually doesn't take me morethan 1/2 an hour. The most important thing to me though, is that I know it's done to my satisfaction and done right.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
