Help Diagnosing Screaching/crackling Noise
alvocado
For the past week, my '02 Yukon Denali has been making a really strange noise. My wife described it as the sound you would hear if you were dragging branches under the truck while moving (sounds rediculous but after driving it, I see how she would think that.) It occurs while accelerating and I think it may only occur when the A/C is on. The A/C is still blowing cold but I could not reproduce the issue while running with the A/C and cabin fan off. I thought the sound was similar to a starter motor screaching/crackling but it never happens while starting the car, only while accelerating. It's definitely coming from the engine bay vs. suspension. I've also noticed the idle is quite a bit rougher with the A/C running and much rougher than the typical load you would experience with the A/C on, however it goes to normal after turning the A/C off.
I know this is a bit generic but I'm having a hard time pinpointing it while driving. Could this be an A/C compressor going bad? My first thought was something on the belt since it seems to be tied to engine RPM. Any ideas on where to look would be appreciated. Thanks.
I did some more diagnosing this evening. There is an audible ticking noise present which under acceleration, could be he source of the issue. Is it possible that a bad valve or lifter could be the cause. It was difficult to reproduce the sound but it did occur while I had the RPMs around 1500 using a broom handle and standing outside the car. The source did not seem to be coming from the belt accessories as previously thought but it was hard to tell from standing by the drivers door.
Problem identified: it's the A/C compressor and likely related to the TSB posted on the forum: http://www.gm-trucks.com/forums/index.php?showtopic=41863. I didn't find that on my first search since it was related to the tensioner. Thanks to orangeman91 for the autoaironline.com referral. I just ordered everything I need for $376 shipped vs. $700 from the dealer.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
