Hi .. I have a 2003 GMC sierra ext-cab 4x4 with 16k on her. I'm having a problem with the Odometer/Trip/Hr. When I start my truck it always changes from english to french or to spanish. Then I change it to english and then I will drive it to the store or something it will change back to french or spanish. I dont really use my truck to much in the summer because I ride my streetbike to work. I use the truck once in a while . She has a new battery in her (the factory battery terminal broke off spilling acid on my battery tray) Does anyone have an idea what might be causing my problem??
Thanks
Subject: Information on How to Change IPC/DIC Language - keywords cluster display English French IPC Spanish trip #PIT3404A - (07/25/2006)
Models: 2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 Chevrolet Silverado Classic
2003-2007 GMC Sierra Classic
2003-2006 GMC Yukon, Yukon XL, Yukon Denali Models
This PI has been revised to add additional model years. Please discard PIT3404.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Starting in model year 2003, the IPC/DIC is able to read out in 3 difference languages: English, Spanish, and French. Some questions have been received concerning how to change the DIC Language, mainly on vehicles without steering wheel controls.
Recommendation/Instructions:
To change between the languages on vehicles with steering wheel controls, follow Document ID # 867116 in SI.
Vehicles without steering wheel controls follow the procedure below:
Turn ignition on.
Use the trip rest stem to display the Odometer on the DIC.
With the Odometer displayed press and hold down the trip reset stem, after 3-5 seconds the DIC will begin to scroll thru the 3 difference languages.
Continue to hold down the trip reset stem until the desired language is displayed then release the trip reset stem.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Did you find a solution to this problem. I am having the exact same problem?
Yes.. I know how to change the languages .... My problem is that the truck is changing them on its own.
What would cause that ??
Is a reprogram a dealer only thing?? Also, what will they reprogram? It is almost like the button (the one that resets the trip meter and scrolls through the Odometer, Hourmeter) is sticking or it thinks its sticking?
sounds like it could use a reprogram
I have a 03 gmc z71 that my 16yr. son drives with the same problem. It has a mind of it's own. I was driving it this week and all of a sudden it started flashing language options. We have reset the language to english with the trip button per instructions above, but it started flashing three languages option shortly afterwards. After 10-15 minutes, I looked at it and it was in French (I think). I have disconnected battery hoping it would reset but on vale. Today when I attempted to reset it again, the odometer/mileage reading did not display. It only flashed language options and I understand it can only be reset while displaying the mileage.
What's involved in a re-program? Any help would appreciated.
Ed
I have a 2003 Yukon and yesterday I reached 59,000 miles. Since then, the display started to change settings, from odometer, to tip, etc., and today, it started to change languages, similar to what has been described in previous posts on this thread. I have set the language to English a few times already only to find that after a few minutes the display is changing settings again. The trip resets constantly from the time that the engine is started to the time it is turned off.
A reprogram of the computer has been suggested but there are no responses on whether this solves the problem or not. Any ideas? Does this have to be done at the dealer or can a do-it-yourselfer do it?
To provide up update for future reference, I took my Yukon to the dealer and asked that they check on reprogramming of the computer. Well, to make it short, I was advised that the cluster panel needs to be replaced, reprogramming, in my case, will not solve the issue.
  • 9 months later...
We have all repaired the steeper motors what is there to fixing for a repair on the language switching problem?? Any help would be greatly appreciated.
  • 5 years later...
I had the random language scrolling on my 2004 Silverado Z71. I sent it off to automotive circuit solutions for $100 they did a full rebuild and installed blue leds. Issue is gone and service came with a lifetime warranty. Check them out automotivecircuitsolutions.com I highly recommend them.
I have had (2)  online online instrument clusters of the years to repair the odometer scrolling problem on my 2004 Tahoe.
As everyone in this forum  knows it can be fixed but the problem comes back. Now I have it for the 3rd time. I am the original owner of this vehicle and never got a recall notice.
Can anyone answer what exactly is the part  that fails when this happens, where to buy it and how to repair  it?
I really can't afford to keep fixing this and there is only 91000 miles on it
  • 7 months later...
I had the same language scrolling issue on my ‘04 Yukon. After searching the interweb I came across someone who recommended changing out the button on the circuit board that is used to select trip miles, miles, language and such. Basically the switch has malfunctioned. I used Radio Shack part # 275-0002 from eBay. Super cheap. Carefully replace this switch. It fixed my issue that I’ve had for a couple of years. I already replaced all of the stepper motors to fix that issue.
I own the 2007 Chevy Silverado Classic WT and I've had the problem since I bought it, but not anymore...
Step 1: disconnect the battery terminals.
Step 2: unplug the cluster connector.
Step 3: plug the cluster connector back in.
Step 4: reconnect the battery terminals.
This will fix the language scrolling issue.
Edited by Screw GM
because i wanted to
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
