Shift Times
On the way to work i noticed on my truck which is stock performance parts but has lift and tires when you get on the gas it will scream in the high RPMs past when it sould be shifting then shift and take off, im buying a tuner soon how much will the tune fix the long shift periods? tnx
It should help a lot, and with most tuners (Edge, Diablo, and Superchips right off the top of my head) you can correct for your tire size, which will in-turn correct your shift points (your truck will shift at the proper rpm again). The tuner will also remove most of the delay and firm up the shifts considerably. I think you'll notice a tremendous difference!
he is correct ... i put a wait4me in my truck a few weeks ago ... it was amazing ... at WOT before my truck would shift from first into second and then just sit there ... now it shift right into second and gooooes ... very nice ;)
