Second Battery Space
I am planning on putting in one of those plastic battery boxes used in boats that straps down and has a cover. Then I can use it as a storage box for a tow strap, a few tools, etc. May as well use every bit of storage space available, right?
i have thought about one of those plastic boxes as well in my second battery spot .. good place for jumper cables and a few other odds-n-ends ...
Hi, first post here.
Why did they move it (battery) anyways? Now you have to take off that small stabilizer arm under the hood to get the battery out.
But putting a marine box for tools such as straps and whatever is a good idea.
So that in a collision Onstar will still (likely) have battery power to contact help.
In theory, that makes sense, but the only trucks that actually have the 2nd battery are Diesels and gassers with snow plow prep pkgs.
The 1st/standard battery, is the one monted near the fire wall on the passenger side. In a frontal collision this battery will be less likely to be knocked loose, busted, disconnected (in theory :)) and still be able to power the Onstar system. The second battery is simply to provide additonal reserve power, and that is why it is on Diesels and Plow Prep package.
So since my 2006 1500 has the snow plow prep package, I can have two batteries(one battery and a storage box)? I sure haven't seen two under there...but I could be wrong. I'll have to check.
On the 2007 GMT-900 there are two battery trays. Onei s in use (duh) the other is empty, with the possiblity of either adding another battery (apparently included on diesels and plow prep package) or adding an aftermarket battery/storage box.
Your truck (GMT-800) may not have a second battery (Depends on what the plow prep package included a second battery at that time) or tray for that matter, but the whole get up is available from GM.
The "second" battery location for 99-06(07classic) is near the firewall on the passenger side and unless factory optioned there is no tray mounted. There are posting somewhere with all the factory part numbers for the tray, relay, isolator and harness.
It is for diesel or the auxillary power option for camper/trailer.
It's been used, as mentioned for storage and locating the air pump for bags etc.
So out of curiosity, where would I get one of the marine storage boxes to mount in the second battery location?
Thanks!
Anthony
it's just a basic plastic battery box...pep boys, autozone, and I think Wally's Mega-Lo mart has them.
They are all over the place here in the desert....supposedly Arizona has a fairly high per capita boat ownership.
The snow plow prep package (RPO Code VYU) does not include a 2nd battery,It should but it dosen't,It must be ordered as a seperate option (RPO Code TP2)
