Looking To Upgrade Headunit
I currently have a basic XM CD Player Headunit with iPod connectivity. Im looking for something with at LEAST a DOT Matrix display. All of sonys new stuff is BUTT ugly. Panasonic and Pioneer have some decent stuff, and Alpine is on drugs. Who else out there has single DIN headunits with a dot matrix display that costs less then like 300 bucks?
i have an alpine one .. that 'is on drugs' .. so sorry i can't be much help ... (but i paid 280 for it, the install stuff and all, for 100 more i could have upgraded to their higher end display)
Since you have a single DIN, you might want to look at the new Pioneer navigation radio that just came out. I believe it is the N4. I just put an AVIC Z1 in and love it. Good luck.
2003 Chev Silverado Duramax, AirRaid, Banks, 5" exhaust
2004 Merc Marauder, 4.6 Cobra, K & N, Flowmaster
Any of the pioneer premier decks are going to be great. The more ya spend, the better it gets. :rolleyes: I normally check 'em out at the local electronic stores first and make sure you like the controls, layout, looks, features, etc.
Well just keep in mind, I have a budget of 300 as I will order up a wait4me at the same time. Here are some that I like
http://www.crutchfield.com/S-7Rdm6ciDkTp/c...;display=XL#Tab
http://www.crutchfield.com/S-YBlmjDwqWXG/c...C8303&g=300
http://www.crutchfield.com/S-YBlmjDwqWXG/c...mp;I=130DEHP490
http://www.crutchfield.com/S-YBlmjDwqWXG/c...amp;I=105KDG730
http://www.crutchfield.com/S-YBlmjDwqWXG/c...mp;I=130DEHP590
http://www.crutchfield.com/S-YBlmjDwqWXG/c...&I=113MP635
My close friend has this : http://www.crutchfield.com/S-YBlmjDwqWXG/c...&I=158GT710
Its nice but not sure If I like the buttn setup. Screen and display are beautiful,as wellas backlights
Out of those choices, my vote would be for the Pioneer DEH-P5900iB. You could also step up to the DEH-P6900UB and get a built-in USB input.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
