Took 1st Place The Other Day
hey yall had to bragg, i went to a car show the other day and took 1st place.....kinda cool, it was a small show here in maryland but defently hot non the less....i got burnt! so here are some pics.
Hey Meester... the peectures they no show up.
i just looked at it they show up for me????
Unless the truck looks like a white box with a little red X in the middle... It no workee here. Tried Firefox and IE.
