How Hard Is It On The Transmission To Downshift Often?
We live out a bunch of backroads where the terrian is quite uneven. I have always downshifted on long descents. Lately, I have been doing it a lot more often to keep the wear off the brakes.
Is this ok for the drivetrain? Am I going to hurt the transmission? Just wanted to make sure I wasn't going to pay for my habbits later.
Truck is an '06 Silverado 5.3L 4.10 4x4 with automatic.
Thanks,
Matt
Downshifting an automatic manually? . If you're actually under power towing something up a hill downshifting won't hurt the transmission as long as the fluid temp stays low.
Edit: Okay I guess I said something wrong about the 4L60. It does have an overrun clutch and will engine brake when manually shifted into a lower gear.
Forgive me if I am wrong, but Bryan, I thought down shifting slows the engine which in return slows the truck whether or not there is an "engine brake" or not.
True... but a lot of automatics just freewheel instead if they don't have a way to lock up. I made the assumption that the 4l60 just freewheeled when in fact it has a clutch to lock up the transmission when you manually shift it lower.
Yeah, it must have a clutch because it does slow it down and the engine RPMs get high, and if you shift into first and have too much speed it's a heck of a jerk (not that I've done that mind you).
I am not sure about dowshifting as a means for braking, but constant shifting up and down while towing is the biggest contributor to heat build up in your fluid and of course, heat is the biggest killer of auto transmissions.
I would not think you would get a lot of extra heat build up from simply dropping a gear while decending a hill but I am not 100% of this.
As long as you're not locking up the tires or otherwise abusing it, I think you'll be fine. If fact, I think my owner's manual mentions something about manually shifting to lower gear when going down steep hills.
I do it every once in awhile just to rap out the pipes... :cheers:
I do that in slushy, icy, and snowy roads. Already might have it in 4WD when approaching a hill, but before going down I will downshift to 3 or 2 to let the engine control the speed of the vehicle. Keeping it from freewheeling and keeping all 4 wheels in a slow, controlled movement forward. In such cases IMO having the engine and gear do their job is safer than random braking which can easily cause a wheel or wheels to skid.
I do it every once in awhile just to rap out the pipes... :banghead:
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
