Eec2200 , R/ C 2" Block / Helwig #7685 Fsb : Gmt900
FYI :
The Readylift coil spacer is approx 1.5" thick - designed so that you don’t have to cut the stock studs atop of the strut - they do come with small dia flange nuts..
There is a wire harness each side ( drivers / passenger ) that did use the extended stud to attach, this design causes the wire harness to flop around..
Designed to fit 285/70-17R tires but do require some inner fender modification
Upon installation - its not really a true level - the front is approx .375 lower than the rear - still nose down !!!
To do : already ordered : gonna be a busy weekend ,,,
EEC2200 ordered from Trumotorsports - delivered for $380 - a authorized dealer so I will be receiving the $50 refund .. :-))
Rough country 2" lower spacer to be installed with Hellwig Front Stab Bar # 7685 - removal of Readylift #66-3080
Recommended :
Hellwig Rear Stab bar already installed #7800 - this is a must !!!!
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   6 Members, 0 Anonymous, 875 Guests (See full list)
