Newb!
win4wiin
I parked my 2003 Avalanche (now for sale) and picked up my new truck on Oct 1st. It's nice to be in a big truck again. Let the mods and add-ons begin!
Chevy Silverado Duramax 2500HD LT2 Z-71 4x4
Welcome....Sharp rig,One of these days I'll get a DMAX
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
