My Proof...
04z71steve
Well with the heat wave running across Chicagoland i decided the best way to spend the last warm days was out on my boat... so we got there and all and had a beautiful day... brought my girlfriend and everything was great... 93 the whole day with sunshine... needless to say i had a great day and was ready to go when i hear SCREEEEEEEECH.... and i look over and o wait what!?!? a ford boy in trouble... he had a 20' single tandem trailer and he was STUCK ON THE RAMP..the ramp runs out about 10 feet in and turns to sand and gravel...i normally pull my rado in about 2 feet deaper cuz my boat is longer and its nothing for her to accomplish she yanks it right out! ... anyways, he had guys trying to push him up the ramp and this and that and finally i walked over and i was like listen... I'll pull u out and he got that look of defeat on his face!!! :crackup: : :D:thumbs: ... so i hooked up the rado from hooks to hooks... threw her in 4wd... and literally... YANKED him out... it was sick people were laughing histarricaly!!! needless to say.. he made a GREAT day into one of the proudest moments of my life :fume: love my rado :nonod: ...
figured you guys would get a little chuckle out of that!
steve :cheers:
What do you mean by "he was stuck on the ramp"?
well when you back down the ramp it runs out after about 10 feet and you'll hit like pea gravel... trialer tires sink like 2" and he just couldnt keep from spinnin em... this he had a 2wd... and thing sounded like it wanted to blow up on him... i actually felt bad... thats why i didnt get any video.. .plus he was like 60 so i wanted to show a little respect to him and his wife... cuz u could tell the whole situation was kinda gettin under his skin a little... BUT GOD I WANTED VIDEO SO BADLY!!!!!
