4wd Switch, 2003 Yukon
I need a new auto-transfer case selector dashboard switch for my 4WD 2003 Yukon, last 8 on VIN is 3R179293. There are confilicting posts on this board about the correct part number (apparently by year model). I know it needs to be replaced already. I just need the correct p/n.
Thanks, Brian
Brian,Double check the last eight of the VIN you gave,I ran it on GM-Dealerworld but it came up as an Escalade......
GM Vehicle Inquiry System
Vehicle Build
VIN 1GYEK63N63R179293
VEHICLE BUILD
Merchandising Model : 6K15706 -2003 ESCALADE
Gross Vehicle Weight Rating : 3178 kg (7007 lb)
Order Number : FTHNGN
Build Date : 11/20/2002
Build Plant : 13R06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - ADJUSTER FRT ST POWER, MULTI- DIRECTIONAL, DRIVER
AG2 - ADJUSTER PASS ST POWER, MULTI- DIRECTIONAL
AJ1 - WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS
AJ7 - FRONT & SIDE IMPACT AIR BAGS
AL0 - PASSENGER DETECTOR
AL4 - SECOND ROW BUCKET SEATS W/HEAT REPLACES SECOND ROW BENCH SEAT
AN3 - SEAT FRT, INDIVIDUAL (NON BKT)
ARL - PLANT CODE ARLINGTON, TX USA
AS3 - SEAT RR SUBURBAN/UTILITY
AU0 - LOCK CONTROL REMOTE ENTRY
AXP - VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
A31 - WINDOW POWER OPERATED, ALL DOORS
BS1 - INSULATION ACOUSTICAL PKG
BVF - STEPS RUNNINGBOARD, SIDE, COLOR KEYED
BW2 - MOLDING B/S DELUXE
B30 - COVERING FLOOR CARPET
B58 - COVERING FLOOR MAT, FRT & RR CARPETED INSERT
CJ2 - MULTI-ZONE AUTO CLIMATE CONTROL
C25 - WIPER SYSTEM RR WINDOW, INTERMITTENT
C36 - HEATER AUXILIARY
C49 - DEFOGGER RR WINDOW, ELECTRIC
C5W - GVW RATING 7,000 LBS
C69 - HVAC SYSTEM RR AIR CONDITIONER
DF5 - MIRROR I/S R/V LT SENSITIVE, COMPASS, O/S TEMP DISPLAY
DH2 - MIRROR I/S FRT VAN LH & RH, ILLUM, WITH DUAL SUNSHADE
DK7 - CONSOLE ROOF INTERIOR, CUSTOM
DL3 - POWER, HEATED, FOLDING OSRV
D07 - CONSOLE FRT COMPT, FLOOR,CUSTOM
EVA - TEST DVT, EVAP EMISSION REQ.
E2C - RAPID DELIVERY SYS CUSTOM ORDER
E52 - BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS
FK2 - ARM LH TORS BAR SPRING ADJ
FK3 - ARM RH TORS BAR SPRING ADJ
GT4 - AXLE REAR 3.73 RATIO
G69 - LEVEL CONTROL, AUTO AIR HD
JF4 - POWER ADJUSTABLE PEDALS
JH2 - 4-WHEEL ANTILOCK DISC BRAKES
JL4 - CONTROL ACTIVE BRAKE
KA6 - HEATER SEAT, RR
KC4 - COOLING SYSTEM ENG OIL
KG3 - 145 AMP GENERATOR
KNP - COOLING SYSTEM TRANS, HD
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL AUTOMATIC, ELE.
K47 - AIR CLEANER HIGH CAPACITY
LQ9 - VORTEC 6.0L V8 345 HP
M32 - 4-SPD AUTOMATIC TRANSMISSION
NF2 - EMISSION SYSTEM FEDERAL, TIER 1
NG1 - FEDERAL/NY/VT EMISSIONS
NR3 - AWD TRANSFER CASE
N30 - STEERING WHEEL DELUXE
N94 - 17" CHROME WHEELS
QAN - TIRE ALL P265/7OR17-1135 BW
R4Y - TIRE BRAND ALL GOODYEAR
R9Z - POMS EXPEDITE - SOLD ORDERS TSE
SAF - SPARE TIRE LOCK
SLL - SALES STOCK ORDERS
TL1 - GRILLE SPECIAL
T74 - HEADLAMPS CONTROL AUTOMATIC DELAY
T96 - LAMP FOG, FRT
UB1 - AM/FM CASSETTE & CD
UD7 - SENSOR INDICATOR REAR PARKING ASSIST.
UE1 - COMMUNICATION SYSTEM VEHICLE
UG1 - OPENER GARAGE DOOR UNIVERSAL
UK3 - CONTROL STEERING WHEEL, ACCESSORY
UK6 - RADIO CONTROL RR SEAT & EARPHONE JACKS
UQ7 - SPEAKER SYSTEM PREMIUM PERF. ENHANCED AUDIO, BOSE
U1S - PLAYER MULTIPLE COMPACT DISC PASS COMPARTMENT
U42 - REAR SEAT ENTERTAINMENT
U84 - ANTENNA BODY SIDE WINDOW, RADIO
VFF - VIDEO FORMAT REGION 1 NTSC
VT4 - BUMPER FRT COLOR KEYED
VT5 - BUMPER RR COLOR KEYED
VXS - VEHICLE COMPLETE
VZ2 - CALIBRATION SPEEDOMETER A
V1K - LUGGAGE CARRIER
V54 - LUGGAGE CARRIER ROOF, PAINTED
V76 - HOOK TOW
XAN - TIRE FRONT P265/7OR17-113S BW
YAN - TIRE REAR P265/7OR17-113S BW
YD3 - AXLE (BASE EQUIP)
YD6 - SPRING RR BASE EQUIP.
YE9 - CONVENIENCE PKG COMFORT & DECOR LEVEL #3
Y91 - MERCHANDISED PKG LUXURY EDITION ZHS - TIRE SPARE P265/75R16-114H BW
ZY1 - COLOR COMBINATION SOLID Z55 - CHASSIS PACKAGE BI-STATE REAL TIME DAMPING
Z75 - CONVERSION NAME PLT CADILLAC 47U - GREEN ENVY
6XK - COMPONENT FRT LH COMPUTER SEL 7XK - COMPONENT FRT RH COMPUTER SEL SUSP
92I - INTERIOR TRIM PEWTER 922 - PEWTER LEATHER
© 1998-2005 General Motors Corporation. All Rights Reserved.
Dale,
Thanks very much for your help. The complete VIN on my 2003 Yukon is: 1GKEK 13Z8 3R17 9293
Looking for the dashboard 4WD switch and would also appreciate the p/n for the spark plug wire set.
Thanks again!
Brian
Man Brian,That VIN still does not come up at all! Theres a digit wrong somewhere.
Lets try this...Look inside your glove box and give me the Transfer Case RPO code,It'll be a code like one of these...NP1,NP2,NP8 or NR4.
That should tell me for sure!
On the plug wires...There are two different part numbers...88894393 which are 9.2" long and used with coils stamped 19005218-DELPHI COIL,and 88894394 which are 10.5" long and used with coils stamped 12558693-MELCO COIL.
Hey that worked!!
The part number you need is 15136039.
Heres the build sheet on it........
Vehicle Build
VIN 1GKEK13Z83R179263
VEHICLE BUILD
Merchandising Model : TK15706 -2003 YUKON - 4WD
Gross Vehicle Weight Rating : 3087 kg (6807 lb)
Order Number : FSRCFT
Build Date : 11/19/2002
Build Plant : 13R06
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER
AG2 - POWER FRONT SEAT ADJUSTERS
AJ1 - DEEP TINTED GLASS
AJ7 - DRIVER/PASS FRT & SIDE AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AN3 - FRONT FULL-FEATURE RECLINING BUCKET SEATS
AP9 - CONVENIENCE NET
ARL - PLANT CODE-ARLINGTON, TX
AT5 - MIDDLE 60/40 SPLIT FOLDING BENCH SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AXP - MPV VIN IDENTIFICATION
A31 - POWER WINDOWS
BVE - ASSIST STEPS
B30 - COLORED - KEYED CARPETING
B39 - CARPETED LOAD FLOOR
B58 - FRT & CTR CARPETED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
CF5 - POWER SUNROOF HOMELINK
CJ2 - TRI ZONE AUTOMATIC AIR CONDITIONING
C25 - REAR WINDOW WASHER/WIPER
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS
C69 - REAR AIR CONDITIONING
DF5 - LT SENSITIVE INT R/V MIRROR W/OUTSIDE TEMP & COMPASS
DH2 - ILLUM LH & RH VISOR MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE
DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL &GROUND ILLUMINATION
DT4 - SMOKER'S PACKAGE ***DEALER INSTALLED***
D07 - FLOOR SHIFT CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E52 - LIFTGATE W/LIFTGLASS
FE9 - FEDERAL/NY/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH
GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JC4 - HEAVY DUTY POWER DISC BRAKES
KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
L59 - VORTEC 5300 V8 BI-FUEL ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHL
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
NZZ - OFF ROAD - SKID PLATE
PDC - CARGO PACKAGE
PDF - SOUND SYSTEM PLUS PACKAGE
PDQ - SECURITY PACKAGE
QC3 - POLISHED CAST ALUMINUM WHEELS
QIX - LT265/75R 16C OOR BW TIRES
RYJ - RETRACTABLE CARGO AREA COVER
R6J - CUSTOMER DIALOGUE NETWORK
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPKR SYSTEM
UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER
UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U2K - XM SATELLITE RADIO-100 CHANNELS OF COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA)
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V1K - LUGGAGE CARRIER CROSS RAILS
V22 - CHROME GRILLE SURROUND
V54 - ROOF MOUNTED LUGGAGE CARRIER
V73 - STATEMENT OF CERT. U.S.
V76 - RECOVERY HOOKS
XGL - LT265/75R16 TBLS OOR SB RAD B/W
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
YGL - LT265/75R16 TBLS OOR SB RAD B/W
ZGL - LT265/75R16 TBLS OOR SB RAD B/W
ZM9 - HOMELINK UNIVERSAL TRANSMITTER
ZV1 - MSO REQUIREMENTS
ZY1 - SOLID PAINT
Z71 - OFF ROAD CHASSIS EQUIP PACKAGE
Z82 - HEAVY DUTY TRAILERING EQUIP.
Z88 - GMC TRUCK NAMEPLATE
1SD - SLT DECOR WITH LUXURY EQUIP GRP ULTRASOFT FRONT LEATHER SEATING SURFACES ASSIST STEPS FULL FUNCTION FRT BUCKET SEATS BOSE PREMIUM 9 SPEAKER SYSTEM REAR SEAT AUDIO CONTROLS VORTEC 5300 V8 ENGINE CARGO PACKAGE INCLUDES CARGO NET LUGGAGE CARRIER CROSS RAILS POWER ADJUSTABLE PEDALS ONSTAR COMMUNICATION SYSTEM STEERING WHEEL CONTROLS POWER FOLDING OSRV MIRROR
1SZ - OFF-ROAD PKG DISCOUNT
50U - SUMMIT WHITE
52I - NEUTRAL INTERIOR TRIM
522 - NEUTRAL INTERIOR TRIM
6XM - COMP FRT LH COMPUTER SEL SUSP
7XM - COMPONENT FRT RH COMP. SEL SUSP
  • 1 year later...
I've run into the same problem changing wires on my '03 1500, except I cannot figure out which coil I have. Where is the stamping on the coil? Do I have to take something apart to see the stamping? I can feel something that might be raised lettering on the bottom side of the coil, but I'm going to have to take the coil off to be able to read it. I'd like to figure out which coil I have without taking the coil off, if possible. FWIW, my plug wire boots say "Delphi" on them...
