Exhaust Replacement On My '00
This has been put off long enough. My Cats are shot and the e-test is up & coming. So I want to re-pipe.
The magnaflow cats (http://store.summitracing.com/partde...part=MPE-93419)seem to be the best stainless kit out there and the Gibson extreme duals are the ticket for my longbox. http://store.summitracing.com/partde...part=GIB-65007 (Not looking for an obnoxiously loud exhaust this time)
We get loads of salt on the roads here so I want everything to be stainless/corrosion-free.
My question is about headers. Do I go for stainless steel headers or regular steel headers coated with ceramic? The stainless model from Gibsons has a nice thick flange (3/8”) and is 16 gauge construction http://store.summitracing.com/partde...art=GIB-GP116S
But is stainless a durable material? I want this system to LAST. The edelbrock headers seem to be of similar flange and gauge http://store.summitracing.com/partde...5&autoview=sku and could save a bit of quid by going this route compared to some of the other ceramic coated steel.
Will these “shorty” headers match up with the replacement cats I’m getting. I’m assuming a direct swap, am I way off base here? Thanks in advance.
G
PS Anyone ship Summit to Canada? Any suprise costs? Thx.
G
My opinion is to keep the stock exhaust manifolds. It will make passng the emissions tests much easier.
G
I would agree you should either stay with stock exhaust manifolds or consider the dynomax hi-flow cat/header system. I replaced my cats with a stock GM Y-pipe primarily because I'm getting up there in mileage (199K) and I wasn't going to keep it very much longer it didn't make sense to go with the dynomax solution.
The shipping to canada is a complete surprise, they don't tell you what the cost is, they just let you pick slow medium fast and tell you youll get charged after.
Yeah so my reason for headers was an apparent leak in the manifold but its a manifold bolt that's snapped on the drivers side closest to the firewall. Great. So they're gonna stay on there for a little while, or until the next one along lets go. I guess I'll take that $$ and replace the Oxy sensors to get some mileage back!
The magnaflow cats will end up just more than 1/3 the price of the GM set so that's a no brainer.
Thx for the replies
G
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
