Help With Tranny Trouble
Jacques
92 Chevy Silverado
Originally 350 engine, now changed to 305
3 speed auto with overdrive
Supposedly a "shift kit" in it
Lots of miles - bought the truck with a busted odometer, and it reads about 150,000+ miles
When I bought it, the tranny shifted a "little" hard, but I was told that was because of the shift kit. I bought and installed an AEM cold air intake that came with a 1" TB spacer. After the cold air intake install, shifting was now at a silly high RPM. I eventually discovered that the kick down cable was too tight, causing the tranny/ECM to think the throttle was open a lot more than it really was. I disconnected the cable, and drove it like that for 4-5 months (I now realise that this might not have been a good idea).
The other day, 3rd and overdrive stopped "driving". It'll run fine in 1st and 2nd, but as soon as the vehicle speed is high enough to shift to 3rd, there's no drive. It's as though the tranny is in neutral. I tried running it with the kick down cable reconnected, and the shift points go up higher like they did before, but the drive is gone in 3rd and OD. I'm guessing that the dropped line pressures from running the tranny without the cable connected have lead to some sort of internal failure. I'm wondering if this is something the can be fixed through the bottom of the tranny (pan) or if I should just take the tranny out and bring it to the transmission shop for repair.
On another note, when the previous owner changed from the 350 to the 305 motor, they did not change the ECM. The chip has "AWLB" code on it. I'm told by the boys at Superchips that this is the code for the 350 programming, but that it should be fine fo rthe 305 motor. I have my doubts, and would like to try a chip specific to the 305 motor.
Thanks for reading, and here's hoping its nothing too serious. :smash:
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
