Rear Differential Fluid Change Interval
I have a 2007 NBS Sierra Crew Cab with NHT Max Trailering package. This has the 6.0L, 4.10 gears with locker and I believe the same rear differential as 3/4 ton (definitely bigger than 5.3L trucks). I tow a ~6500# travel trailer a few times a month.
Anyway, I looked through my owners manual again last night, and I don't see anything about when the differential fluid should be changed. I know they're filled with synthetic from the factory, so I'm thinking it's ok to wait until 25k miles or so. Maybe 50k would even be OK similar to transmission under heavy use.
Any thoughts on this? I've seen some folks mention changing after only 500 miles, but maybe that was with dino fluid.
Thanks!
Thanks!
If you do heavy towing every day that would be every year, but since your only doing it few times a month would be good to change it a 30-40k
When I change mine I'll deffinatley be using Royal Purple Max Gear or Amsoil Sever Gear and while i'm at it upgrade to a Mag-Hytec cover. I'm planning at changing around 25-30k
I have seen some people say the differential should be changed after a break period. The logic: during break in there could be some metal flakes so it would be good to get them out.
I've always done my first rear-end fluid change at 3,000 miles,Then about every 15,000 miles after that.And it dosen't matter if it has regular or synthetic lube,I change it at the same intervals.
That might be overkill but I just feel better doing it at those intervals.
All GM power train components have magnets to collect any particles during the recommended service cycles. Normal driving is about 100000mi. I have service trucks the oldest is a 2000 with 240000+ that tows an equipment trailer and we didn't change an fluids until 100000mi. As of now no drive line problems.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
