In-line Fuel Pump
I am adding a In-line fuel pump to my silverado. Has anyone done this to their truck. Is so any pictures or insturctions, or brand names would be great. I have done some searching and found this one Fuel Pump. I am just unsure how to tap int othe SS line under the truck. Also we do have a fuel return correct?
That is what i am trying to figure out. I deffentially do not want to add one but a lot of people that I talk to say more boost more fuel = in line fuel pump.
Your stock pump will NOT support your goal of 8psi on your motor and you will need to upgrade your in tank pump or add an in-line pump. I have both a walbro-220 in tank and an in-line GSS340 (2 pumps) on my truck.
Looking at your stats, I see you have an 03 which is a GOOD thing in that the fuel system is a return system (although I have seen some bastard trucks with a returnless system in late 03). You have a few options here and by far the easiest one will be to add an in line GSS340 in line fuel pump. I suggest calling Magnacharger and ordering their in line set-up for the Radix kits on your model truck. The pump will come with a complete set-up that mounts where your fuel filter is on your frame rail and taps into your exsisting fuel pump via a relay. NO FAB WORK will be needed except for drilling a mounting hole to secure the pump.
The 03 return fuel system also has a boost / vac referenced fuel pressure regulator which ultimately gives the truck fuel pressure to idle around 52psi to a WOT (full boost 8psi) of 62-63psi. The returnless systems have a static pressure of around 58psi. The additional fuel pressure for the 03 trucks gives more breathing room because the injectors are really flowing alot more than rated. I don't know if I asked but what size injectors are you running? Please tell me you are using the 42#rs as anything smaller, you run the very likely risk of going lean and melting a piston or two. If you are running the powerdyne on stock injectors and stock fuel pump, PLEASE upgrade to save your truck.
I know you run a powerdyne set-up and they are notorious for not having complete kits. Please do your homework before turning up the wick on boost. :)
BTW, Who does your tuning?
EDIT: I found out you are running an FMU. Lose it. Buy yourself some marine 42# multecII injectors, the in-line fuel pump I discussed and find a tuner to set-up your PCM for the new hardware. Any competent tuner worth his/her salt can cut a mild cookie cutter tune to get you started (hell, a mail order tune could work well - I suggest Lydon at Wester's Garage). Once you are all buttoned up and the new flash in your PCM, get on a dyno and do a 3rd gear pull. Have your tuner dial in a safe 11.9 AFR. Swap your blower pulley and do another pull KEEPING A CLOSE EYE on the AFR. Adjust the fueling as needed and then have fun adding spark advnace :cheers: It will be fun seeing the HP increase as you add advance. Keep it conservative (I would say 13-14*) unless you don't have any KR then give her a few more ticks.
