Replacing Shift Solenoids Diy
4L60-E tranny threw a DTC PO753 code: 1-2 shift solenoid elec malfunction. Want to change this out myself, Is this a simple R&R solenoid or are there more technical aspects to it?
It can be time consuming, (lots and lots of labor) but should be straight forward, however you are going to have to get to the part in order to change it out, may require removing other parts.
Just found the exploded view:
(38)Transmission Case Plug -- Accumulator Bleed
(39)Pressure Plug
(40)Third Accumulator (#7) Retainer and Ball Assembly
(41)Band Anchor Pin
(42)Retainer and Ball Assembly -- Double Orifice (#10)
(43)Accumulator Piston Pin
(44)3-4 Accumulator Piston
(45)Oil Seal Ring -- 3-4 Accumulator Piston
(46)3-4 Accumulator Spring -- Model Dependent
(47)Spacer Plate to Case Gasket
(48)Valve Body Spacer Plate
(49)Shift Solenoids Screen
(50)Pressure Control Solenoid Screen
(52)Spacer Plate to Valve Body Gasket
(53)Spacer Plate Support Plate
(54)1-2 Accumulator Spring -- Outer
(55)Oil Seal Ring -- 1-2 Accumulator
(56)1-2 Accumulator Piston
(57)1-2 Accumulator Cover and Pin Assembly
(58)Accumulator Cover Bolt
(59)Accumulator Cover Bolt
(60)Control Body Valve Assembly
(61)Checkball (#2, 3, 4, 5, 6, 8, 12)
(62)Valve Body Bolt
(63)Manual Detent Spring Assembly
(64)Manual Detent Spring Bolt
(65)Wiring Harness Pass-through Connector O-Ring Seal
(66)Wiring Harness Solenoid Assembly
(67)O-Ring Seal -- Solenoid
(68)Hex Washer Head Bolt -- Solenoid
(69)Transmission Fluid Pressure Manual Valve Position Switch Assembly
(70)Pressure Switch Assembly Bolt
(77)Spacer Plate Support Bolt
(91)Number 1 Checkball
(93)Dipstick Stop Bracket -- Model Dependent
(103)Main Section Case -- Model Dependent
(104)1-2 Accumulator Spring -- Inner
and here is the Control Valve Body Assembly:
(350) Control Valve Body Assembly
(353) Forward Accumulator Oil Seal
(354) Forward Accumulator Piston
(355) Forward Accumulator Pin
(356) Forward Accumulator Spring
(357) Forward Abuse Valve
(358) Forward Abuse Valve Spring
(359) Bore Plug
(360) Coiled Spring Pin
(361) Low Overrun Valve
(362) Low Overrun Valve Spring
(363) Forward Accumulator Cover
(364) Forward Accumulator Cover Bolt
(364a) Pressure Control Solenoid Retainer Bolt
(365) 1-2 Shift Valve Spring
(366) 1-2 Shift Valve
(367a) 1-2 Shift Solenoid Valve
(367b) 2-3 Shift Solenoid Valve
(368) 2-3 Shift Valve
(369) 2-3 Shuttle Valve
(370) 1-2 Accumulator Valve Spring
(371) 1-2 Accumulator Valve
(372) 1-2 Accumulator Valve Sleeve
(374) Actuator Feed Limit Valve
(375) Actuator Feed Limit Valve Spring
(376) Bore Plug
(377) Pressure Control Solenoid Valve
(378) Pressure Control Solenoid Retainer
(395) Bore Plug and Solenoid Retainer
