Dang, were back!
chevy4x4trucks
Billing problems at our host caused them to think we didn't pay them....rolleyes.gif
Everything is taken care of now so sorry for the problems we've had today!! Chevy_anim.gif
Another screw up now though.  I only can get to this topic since I clicked it on the main page.  When I click on general/off topic it takes me to page three.   :(
the sites working fine for me.  When it went down I thought that the company got wise to me going on there during the day and blocked it from being accessed.  Phew, what a relief.  JP, try clicking on page 1 and then it should work from there on out.
Yeah, I know, its working like it should now all of the sudden.  What was wrong, I dunno.
I guess the feelings between computers and me are the same, we each hate each other.   :(
I was beginning to think that Kyle had finally hacked in and took it over like the anarchist he is. :(
Well, we know you didn't.  How do I know this you ask?  You wouldn't be here right now, you'd be off drinking it up with the barely pop of your choice.   :(
i hear you there 4x4 i was thinking the same thing yesterday.  i was like what am i going to do all day now. :(
What do you think I was doing last night while all you guys couldn't get on the site?   :P
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
