Onstar
I'm wanting to remove the Onstar unit from my 03 Yukon. I won't be renewing Onstar anymore and won't be upgrading it to the new digital version. I heard that having Onstar will drain power from the battery when the power is off to the car. I was wondering if it's possible to remove the Onstar unit without affecting anything else and if so, where the Onstar unit is located in 03 Yukon. Thank you.
Your Yukon won't let the battery drain much if the power is off. After a certain number of hours/days your truck will shut OnStar off anyway to conserve battery power.
Just leave it in and forget about it. If you sell it down the road the next person may like it.
Where's the Onstar fuse?? And thanks for all your inputs and help. :rolleyes::lol:
Underhood Fuse Block
The underhood fuse block in the engine compartment on the driver's side of the vehicle near the battery. Lift the cover for access to the fuse/relay block.
To remove fuses, hold the end of the fuse between your thumb and index finger and pull straight out.
*1 -- Gasoline Engine and Fuel Injection Rail #2.
*2 -- Gasoline Engine and Fuel Injection Rail #1.
*3 -- Gasoline Engine; Oxygen Sensors.
*4 -- Gasoline Engine; Oxygen Sensors.
*5 -- PCM Ignition
Fuses
Usage
GLOW PLUG
Not Used
CUST FEED
Gasoline Accessory Power
STUD #1
Auxiliary Power (Single Battery and Diesels Only)/Dual Battery (TP2) Do not install fuse.
MBEC
Mid Bussed Electrical Center Power Feed, Front Seats, Right Doors
BLOWER
Front Climate Control Fan
LBEC
Left Bussed Electrical Center, Door Modules, Door Locks, Auxiliary Power Outlet--Rear Cargo Area and Instrument Panel
STUD 2
Accessory Power/Trailer Wiring Brake Feed
ABS
Anti-Lock Brakes
VSES/ECAS
Vehicle Stability
IGN A
Ignition Power
IGN B
Ignition Power
LBEC 1
Left Bussed Electrical Center, Left Doors, Truck Body Controller, Flasher Module
TRL PARK
Parking Lamps Trailer Wiring
RR PARK
Right Rear Parking and Sidemarker Lamps
LR PARK
Left Rear Parking and Sidemarker Lamps
PARK LP
Parking Lamps Relay
STARTER
Starter Relay
INTPARK
Interior Lamps
STOP LP
Stoplamps
TBC BATT
Truck Body Controller Battery Feed
SUNROOF
Sunroof
SEO B2
Off-Road Lamps
4WS
Vent Solenoid Canister/Quadrasteer Module Power
RR HVAC
Rear Climate Control
AUX PWR
Auxiliary Power Outlet -- Console
IGN 1
Ignition Relay
PCM 1
Powertrain Control Module
ETC/ECM
Electronic Throttle Control, Electronic Brake Controller
IGN E
Instrument Panel Cluster, Air Conditioning Relay, Turn Signal/Hazard Switch, Starter Relay
RTD
Ride Control
TRL B/U
Backup Lamps Trailer Wiring
PCM B
Powertrain Control Module, Fuel Pump
F/PMP
Fuel Pump (Relay)
B/U LP
Back-up Lamps, Automatic Transmission Shift Lock Control System
RR DEFOG
Rear Window Defogger
HDLP-HI
Headlamp High Beam Relay
PRIME
Not Used
SIR
Supplemental Inflatable Restraint System
FRT PARK
Front Parking Lamps, Sidemarker Lamps
DRL
Daytime Running Lamps (Relay)
SEO IGN
Rear Defog Relay
TBC IGN1
Truck Body Controller Ignition
HI HDLP-LT
High Beam Headlamp-Left
LH HID
Not Used
DRL
IPC/DIC
Instrument Panel Cluster/Driver Information Center
HVAC/ECAS
Climate Control Controller
CIG LTR
Cigarette Lighter
HI HDLP-RT
High Beam Headlamp-Right
HDLP-LOW
Headlamp Low Beam Relay
A/C COMP
Air Conditioning Compressor
A/C COMP
Air Conditioning Compressor Relay
RR WPR
Rear Wiper/Washer
RADIO
Audio System
SEO B1
Mid Bussed Electrical Center, HomeLink, Rear Heated Seats
LO HDLP-LT
Headlamp Low Beam-Left
BTSI
Brake Transmission Shift Interlock System
CRANK
Starting System
LO HDLP-RT
Headlamp Low Beam-Right
FOG LP
Fog Lamp Relay
FOG LP
Fog Lamps
HORN
Horn Fuse
HORN
Horn Relay
W/S WASH
Windshield and Rear Window Washer Pump Relay
W/S WASH
INFO
OnStar/Rear Seat Entertainment
RADIO AMP
Radio Amplifier
RH HID
Not Used
EAP
Electric Adjustable Pedals
TREC
All-Wheel Drive Module
SBA
Supplemental Brake Assist
