Diagrams In High Resolution
<script src="http://gsi.xw.gm.com/si/gsiFunctions.js"> <script> gmLogoFlat.gif Service Information
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 703625 Parking Brake Rear Cable Replacement - Left Side
Removal Procedure
  1. Release the park brake.
  2. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Relieve the tension on the park brake cables by loosening the nut at the equalizer.
  4. Disconnect the cable at the equalizer.
  5. Remove the cable from the mounting bracket by depressing the locking tabs.
  6. Remove the cable at the shock absorber bracket by removing the bolt.
  7. Remove the cable from the lever (all except 15 series utilities).
  8. Remove the cable from the backing plate by depressing the locking tabs.
  9. Remove the cable.
  • Replies 85
  1. Remove the cable from the lever (15 series utilities).
  2. Remove the cable from the backing plate by depressing the locking tabs.
  3. Remove the cable.
Installation Procedure
  2. Install the cable taking care to correctly route the cable through the guides and the body mounts.
  3. Install the cable to the backing plate by pressing the cable into place until locking tabs snap into place (15 series utilities).
  4. Install the cable to the lever.
  5. Install the cable taking care to correctly route the cable through the guides and the body mounts.
  6. Install the cable to the backing plate by pressing the cable into place until locking tabs snap into place (all except 15 series utilities).
  7. Install the cable to the lever.
    Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  8. Install the cable at the shock absorber bracket and install the bolt.Tighten
    Tighten the bolt to 25 N·m (18 lb ft).
  9. Install the cable to the mounting bracket until the locking tabs snap into place.
  10. Connect cable end to the equalizer.
  11. Tighten the nut to the intermediate cable at the equalizer.Tighten
    Tighten the nut to 3.5 N·m (31 lb in).
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Adjust the park brake cable. Refer to Park Brake Adjustment .
© 2008 General Motors Corporation. All rights reserved.
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 703631 Parking Brake Rear Cable Replacement - Right Side
Removal Procedure
  3. Relieve the tension on the cable by loosening the nut at the equalizer.
  4. Disconnect the cable from the equalizer.
  5. Remove the bolt from the rear axle clip.
  6. Remove the cable from the differential clip.
  7. Remove the cable from the mounting bracket by depressing the locking tabs.
  8. Remove the cable from the left and right side cable guides (15 series utilities).
  9. Remove the cable from the track bar clips.
  10. Remove the cable from the lever (all except 15 series utilities).
  11. Remove the cable from the backing plate by depressing the locking tabs.
  12. Remove the cable from the retaining bracket.
  13. Remove the cable.
s reserved.
  3. Remove the cable from the retaining bracket.
  4. Remove the cable.
  4. Attach the cable to the lever.
  7. Attach the cable to the lever.
  8. Install the cable to the track bar and secure with the clips. Verify that the clips are installed between the locators on the track bar (15 series utilities).
  9. Install the cable to the right and left side guides.
  10. Install the cable to the mounting bracket until the locking tabs snap into place.
  11. Bolt the cable to the differential (clips).Tighten
    Important: After installing the cable to the rear axle holding clip, verify that clip is securely retaining the cable. If not, crimp the clip by hand taking care not to pinch or kink the cable.
  12. Install the cable to the differential clip.
  13. Connect the cable to the equalizer.
  14. Tighten the nut to the intermediate cable at the equalizer.Tighten
  15. Remove the safety stands.
  16. Lower the vehicle.
  17. Adjust the park brake cable. Refer to Park Brake Adjustment .
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 702184 Park Brake Adjustment
Park Brake Shoe Adjustment
Tools Required
J 21177-A Drum-to-Brake Shoe Clearance Gauge
Important: The park brake shoes must be adjusted before the park brake pedal is adjusted.
  2. Set the J 21177-A so that it contacts the inside diameter of the rotor.
  3. Position the J 21177-A over the shoe and the lining at the widest point.
  4. Turn the adjuster nut until the lining just contacts the J 21177-A .
  5. Repeat steps 1-3 for the opposite side.
  6. The clearance between the park brake shoe and the rotor is 0.6604 mm (0.026 in).
Park Brake Pedal Adjustment
Important: Before you adjust the park brake, verify that the park brake shoes are adjusted to provide a clearance of 0.6604 mm (0.026 in).
  1. Verify that the self adjuster lock-out pin has be removed.
  2. Fully apply and release the park brake pedal 3 times.
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 703614 Parking Brake Front Cable Replacement
Removal Procedure
  2. Remove the park brake pedal. Refer to Parking Brake Lever Pedal Assembly Replacement .
  3. Roll the carpet back to access cable grommet.
  4. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  5. Disengage the grommet and the cable from the floor pan.
  6. Disconnect the front cable from the intermediate cable.
  7. Remove the cable from the body mount by depressing the retaining tabs.
  8. Remove the cable.
  2. Install the cable.
  3. Snap the retainer tabs into the body mount.
  4. Connect the front cable to the intermediate cable.
  5. Route the cable in through the floor pan and engage the grommet.
  6. Remove the safety stands.
  7. Lower the vehicle.
  8. Roll the carpet into place.
  9. Install the park brake pedal. Refer to Parking Brake Lever Pedal Assembly Replacement .
  10. Adjust the park brake system. Refer to Park Brake Adjustment .
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 702178 Parking Brake Lever Pedal Assembly Replacement
Removal Procedure
  1. Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
  2. Disconnect the negative battery cable.
  3. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  4. Relieve the tension from the park brake cables by loosening the nut at the equalizer.
  7. Remove the left side hinge pillar panel. Refer to Body Hinge Pillar Trim Panel Replacement in Interior Trim.
  8. Disconnect the park brake warning lamp connection.
  9. Remove the MID-Bussed Electrical Center bracket.
  10. Disconnect the park brake release cable from the park brake lever.
  11. Remove the park brake lever mounting nuts.
  12. Disconnect the front park brake cable from the park brake lever.
  13. Remove the park brake lever.
  2. Connect the front park brake cable to the park brake lever.
  3. Install the park brake lever.
  4. Install the MID-Bussed Electrical Center bracket.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  5. Install the park brake lever mounting nuts.Tighten
    Tighten the nuts to 25 N·m (18 lb ft).
  6. Raise the vehicle.
  7. Support the vehicle with safety stands.
  8. Tighten the nut to the intermediate cable at the equalizer.Tighten
  9. Remove the safety stands.
  10. Lower the vehicle.
  11. Connect the park brake release cable to the park brake lever.
  12. Connect the park brake warning lamp connector.
  13. Install the left side hinge pillar panel. Refer to Body Hinge Pillar Trim Panel Replacement in Interior Trim.
  14. Install the left side kick panel.
  15. Connect the negative battery cable.Tighten
    Tighten the nuts to 17 N·m (13 lb ft).
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 665247 Body Hinge Pillar Trim Panel Replacement
Removal Procedure
  2. Remove door sill plate. Refer to Front Side Door Sill Plate Replacement or Rear Side Door Sill Plate Replacement .
  3. Remove hinge pillar panel.
  2. Install the hinge pillar panel.
  3. Install the door sill plate. Refer to Front Side Door Sill Plate Replacement or Rear Side Door Sill Plate Replacement .
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Diagnostic Information and Procedures | Document ID: 703615 Parking Brake Intermediate Cable Replacement
Removal Procedure
  3. Remove the nut from the threaded end of the intermediate cable.
  4. Disconnect the equalizer from the rear park brake cables.
  5. Disconnect the intermediate cable from the front cable.
  6. Remove the intermediate cable.
  1. Install the intermediate cable.
  2. Connect the intermediate cable to the front cable.
  3. Connect the equalizer to the rear park brake cables.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Install the nut to the threaded end of the intermediate cable.Tighten
  7. Adjust the park brake system. Refer to Park Brake Adjustment .
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Special Tools and Equipment | Document ID: 663458 Parking Brake Shoe Replacement (15 Series)
Removal Procedure
  1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the tire and the wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  4. Remove the park brake cable from the park brake actuator lever.
  5. Remove the rotor. Refer to Rear Brake Rotor Replacement in Disc Brakes.
  6. Turn the adjustment screw (1) to the fully home position in the notched adjustment nut.
  7. Remove the park brake shoe assembly from the backing plate by removing the tips from the slots and sliding the shoe (2) towards the retaining spring (3) until the shoe disengages from the spring.
  8. Remove the park brake shoe assembly from the vehicle by placing one of the open ends of the shoe over the axle flange and rotating the shoe until it has cleared the flange.
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Align the slots in both the adjusting screw and tappet (1) to be parallel with the backing plate face.
  3. Install the park brake shoe assembly (2) to the vehicle by placing one of the open ends of the shoe over the axle flange and rotating the shoe until it is behind the flange.
  4. Position the park brake shoe on the inboard side of the actuator.
  5. Slide the park brake shoe into position and seat into the retaining spring (3).
  6. Inspect the shoe assembly position. The shoe must be central on the backing plate with both tips located in the slots.
  7. Adjust the park brake shoe. Refer to Park Brake Adjustment .
  8. Install the rotor. Refer to Rear Brake Rotor Replacement in Disc Brakes.
  9. Install the park brake cable to the park brake actuator lever.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  10. Tighten the nut to the intermediate cable at the equalizer.Tighten
  11. Install the tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  14. Adjust park brake cable. Refer to Park Brake Adjustment .
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Park Brake | Special Tools and Equipment | Document ID: 707568 Parking Brake Actuator Replacement (15 Series)
Removal Procedure
  3. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  5. Remove the rear park brake cable from the park brake actuator lever.
  6. Remove the park brake cable from the mounting bracket by depressing the locking tabs.
  7. Remove the rotor. Refer to Rear Brake Rotor Replacement in Disc Brakes.
  8. Remove the axle shaft. Refer to Rear Axle Shaft Replacement in Rear Drive Axle.
  9. Remove the park brake shoe. Refer to Parking Brake Shoe Replacement .
  10. Remove the backing plate bolts.
  11. Remove the park brake actuator lever housing from the backing plate.
  2. Install the park brake actuator lever housing to the backing plate.
  3. Perform the following procedure before installing the backing plate bolts.
    2.1. Remove all traces of the original adhesive patch.
    2.2. Clean the threads of the bolt with brake parts cleaner or the equivalent and allow to dry.
    2.3. Apply Threadlocker GM P/N 12345493 or Red LOCTITE™ #272 to the threads of the bolt.
  4. Install the backing plate bolts.Tighten
    Tighten the backing plate bolts to 135 N·m (100 lb ft).
  5. Install the park brake shoe. Refer to Parking Brake Shoe Replacement .
  6. Install the axle shaft. Refer to Rear Axle Shaft Replacement in Rear Drive Axle.
  9. Install the park brake cable to the mounting bracket until the locking tabs snap into place.
  10. Install the rear park brake cable to the park brake actuator lever.
  12. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  13. Remove the safety stands.
  14. Lower vehicle.
  15. Adjust park brake cable. Refer to Park Brake Adjustment .
Hey there,I'm new here, so please forgive me if I am out of line. I have a '01 silverado 1500 extended cab, and I am in need of the chassis electrical diagrams (exterior lighting, trailer, etc.) I purchased the Haynes manual for my truck, but it is one of those that spans a few years, and in doing so they encompassed the major chassis/body change year and did not include the updated schematics. One other item that was not updated were the four wheel disc brakes. The manual only refers to drum brakes on the rear. The reason I brought that issue up is I have no parking brake, all of the components seem to be in place, and operable, however, when the parking brake is applied it hits the floor before enough pressure is applied to the pads to hold the vehicle. I checked for adjustment at the point where the three cables meet underneath, and it seems the factory did not leave any adjustment for me. The pads are not excessively worn, nor are the rotors. I doubt the cable has streched, as the only time the brake has been used in the past is when I have worked undeneath the truck, and rare occasions of parking on a hill with a trailer or other load. Any sugjestions? Sorry about my long windedness, I truly would appreciate any help you can give me.
P.S. While browsing around looking for the digrams I noticed quite a few people with a clunking noise coming from the front of their trucks, I believe that noise can be narrowed down to a sloppy steering column shaft in the engine compartment, I found my noise only after my son was kind enough to try and push a buick out of his way at 50 MPH!!! Thanks again
Duane Englund [email protected]
Hope this helps with finding your problem with the parking brake
WOW! That is an impressive amount of information, and to top it off, you had it posted in a matter of hours, I am truly impressed, and extremely grateful. Hopefully I will be able to put this treasure to use this weekend! I take it the info is out of the factory build sheet/ shop manual? If you are refrencing from a book, is it avail. to the gen. public for purchase? If so, I may be interested. Again, thank you for your swift response, however,(and I really feel like a heel for asking,) did you have any luck locating the electrical diagrams For the same truck? I am in the process of installing a brake controller for my travel trailer, and enclosed utility trailer, and the truck did not come with the upgraded 8 wire trailer harness. I purchased the adapter that connects the controller to the distribution block under the driver side dash, and it seems that the factory ran the wires from the distribution block to a yet to be determined location. If I can locate reliable diagrams that show the wiring harness at it's basic trim level with the optional upgrades I can determine the what, where, and how many I need to install. I have a strong background in electrical, so very complicated diagrams do not intimidate me, judging by the info you gave me on the brakes, I am beside myself in anticipation of what you will come up with !!!
P.S. Thank you for the welcome to the forum, and as soon as I get these two issues resolved and my truck back on all four I will shoot a couple of pics and post. Thxs Again.............Duane
That information actually comes from GM Dealerworld Service Center (Not available to the general public) , but with most requests, I still post it here to help out. Some of this information is contained within the newer service publications from Helm (www.helminc.com) and can be purchased, but the problem is I dont know if they come with the high resolution diagrams that I put online (if they do, will someone let me know). I would have to look at the Service Center to see if I can find anything related to the wiring harness...will let you know.
Here are some of the Electrical Docs that you requested, now I dont know which ones you need, but I can show the electrical as well as the physical. could you by chance tell me where you are trying to jack into? Thanks...
2001 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Body and Accessories | Wiring Systems | Schematic and Routing Diagrams | Document ID: 678970
IGNITION, RUN, and START Bus Bar
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
