Harley Davidson Rims.
like this:
or like this:
the chrome one is has 2 Bolt Patterns Available: 5 x 135mm(1997-2003) or 6 x 135mm(2004-2007) and 20 x 9. as for the second one it is Bolt Pattern: 6 x 135 and 22" x 9"
not sure since the bolt pattern on your truck should be 6-139.
What does the 139 stand for?
139mm...distance from center of one wheel stud to the center of the stud directly across from it.
that equals about 5 1/2"
Ford is 6 on about 5 5/16"
will they fit? small difference.
There is only a small difference between a 7/16" and 1/2" wrenches too. :cheers: The 3/16" difference between the bolt patterns of these two trucks seems small but coupled with the different center bore diameter and lack of compatibiliy of fastening styles (14mm x 2 thrust washer on Ford and 14mm x1.5 taper seat on GM), this has the potential to be one rough riding SOB. I think that the stud length on the GM is too short to boot. To be sure, GM wheels fit the hub exactly. I've not had a reason to check whether Ford wheel center-bore is larger or smaller than GM, but that right there would be a deal breaker for me.
well... Ford / gm mix??? Mabye with king ranch leather interior?!(I wish) but not with rims too obvious to people in the know.
I had read somewhere that GM is working on an interior design that would be a step above the Ford King Ranch :rollin: I have a friend with an F-250 Powerstroke with the King Ranch interior. Very impressive interior; looks like 6 cows died for the seat leather. :lol:
