Gps Antenna.
I want to get a navigation system but it says it comes with a GPS antenna. Do I have to install this myself? Where does it go? thanks
Probably talking about a more extensive unit than I have, but...
I have a Garmin C340. Mounted on the windshield and did not require an additional antenna (But you can get one if you want).
Would think you could just put an external antenna along the base of the windshield if you had one.
Most are integrated into the unit now, but some do give you an option to use an external one instead. They work best if you put them on the outside of the vehicle, in which case they normally have a magnet built-in. But it should work good enough if you put it in a place where it has a direct view to the sky.
Was there a particular model you were looking at?
