Instaling/wiring Subs/system In A 2007 Silverado Z71
Wake117LF
Ok here is what i got, i have a 2007 Silverado z71 and i'm trying to install a system in it. I'm heaving trouble wiring it all together. I've got no problem with wiring the subs and amp. The thing i'm having trouble with is I cant figure out how to correctly wire the amp to the head unit. (I want to keep the stock head unit and use that). Can anyone point me in the right direction about how to wire this up correctly? I've got all the wire and everything else you need to do it i just dont know what wires to hock together is basicly all.
http://www.installer.com/hilo/
Its called a hi/lo converter. look at this and see if it helps
why not just get an aftermarket head unit, then you will have more options tuning wise for your system. you know you are going to get one eventually... might as well just do it now!
If you like to listen to your music loud and bump your system I garuntee if you keep your stock head unit that you will blow the sub and amp if not at the same time then seperatley. I blew 2 subs and 1 amp with my first system which was all brand new top of the line kicker equipment. Save yourself the trouble and get an aftermarket the second I did it sounded better and have had the same equipment for 2 years with no problems (knock on wood).
this makes no sense to me
why would a stock deck cause your subs or amp to blow? i say it was the wiring, but thats just me!
ireally want to keep my stock deck but i want to add a 10" sub for a lil extra thump...and since my truck is a lease, i dont' want to tear the dash apart
so if anyone figures this out, let me know cuz i want to hook it up!
you dont have to tear your dash apart. it sound slike you do if you have neevr done it b4.. but its easy. you pop off the front cover... a few boltls later and un clip the wiring harness and your done taking out your stock stuff. Then when you buy a head unit, you will buy a mount kit as well... you bolt up the deck (which will include a wiring harness for your specific truck, when you tell the store what you need) you plug that after market harness into the stock one... then clip the other end into the deck... as well as your rcas, and your remote wire from your amp (will have to tap that into your after market wiring harness) and then bolt and or clip the mount kit on, then snap the dash cover back on and you are in business. its really not difficult at all.
hardest part (if you are a newb at it) is connecting all the wires (deck will come with a plug w/wires, then the other half of the harness will be wires on one end, and plug for your truck on the other)... have to strip the wires (from both adapters) and connect them all to their respected colors (twist/soilder/heat shink).... if you dont feel comfortable doing it, get the stereo shop to do it. (or even get them to do the whole install, but as most ppl will tell you, no need to spend the money when its simple to do yourself) and as with anything it comes with instructions...and if you do it once, you can charge all your buddys money to do theirs for them lol
in addition.. if you are to move up and get dvd player, nav, ipod connect, bluetooth, and so on, your install gets a little more complicated, and there are a few more wires.... and if your dvd player is like most, they come and are only able to play vids in park... so you either have to know what your doing to change that in your wiring process, or you need to get a stereo shop to do it for you (which they may not do, since it is kind of illegal)
i will tell you one thing, if you do get an aftermarket head unit... dont just get the cheapest one that has rcas just for the sake of an easier install. get something quality, that you like, and wouldnt mind having for awhile. its better to spend the money now, rather than buying a POS for like 100 bucks, then hating it in 3 months when you have money for something better... then going out and buying something better (and having that 100$ waste of money laying in ur garage collecting dust, and being unable to sell it) i made that mistake a few years back when i had my old truck... so with my new silverado i went all out and got a sick dvd/nav/ipod video set up. yeah its close to 1000 for that kind of set up, but my nav has come in sooooo handy, i dont regret spending that money for a second. and down the road i added the bluetooth adapter (which i love) and also a threw a ps2 in for s**ts and giggles... plus since our trucks have room for a double din install, a in dash dvd not only has tons of options, but looks very stock in appearence, and creates a very clean install. (pics below)
  • 3 weeks later...
sick indeed man, sick indeed
so i could use the hi/lo convertor AND keep the stock head unit? (i will NOT replace my head unit)
what about just a 10" sub and keep the stock speakers? does that sound decent? i dont' want to spend more than like $500 (amp/sub/box). i have had a huge system when i owned a prelude but i dont' need that crazy bass anymore..i just want SOME bass (compared to pretty much nothing with the stock sub)
i don't listen to my music at crazy loud volumes either..and it's mostly rock/metal..with some rap
for keeping your stock head unit ... but still having good quality sound.... check out the rockford 360.1 (or .2) alpine also makes a good peice .. that keeps the factory deck ... but gives you a TON of options
They make a complete adapter that gives you RCA's out of the factory head unit. I saw it on ebay a couple of days ago. When I find it ill add the link but just look on ebay.
I have been doing A/V installs, fiberglass.... for a while and also competing in DB drags IASSCA..... I also have no desire to change out my factory head unit for any reason. I will change out to some JL XR's or ZR's and add an 8, 12, 13.5 W7. If you need any other help let me know.
i assume these are amps you mentioned?
i'd like to have a bass control knob too :D they are HANDY
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
