Power Door Lock Problem
Bmuelle
I have a 2008 Silverado with power door locks. At times when I'm driving I can hear the door lock mechinism working without having my finger on the door lock button, however, the door locks don't open or close when it's making the noise. Is anyone else having this problem? Thanks in advance and Merry Christmas.
I had the same thing on my car (Lincoln) that I drive for work. The car had an automatic door locks. The same issue as with you used to happen after driving in rain. So I assume it must have been an electrical short somewhere.
If you have automatic doorocks, disableing the autolock system might help.
Either way I think you should fix the problem as soon as possible, these door lock actuators are prone to fail even under normal operating conditions.
plse don't waste your time ,take it to a dealer ,its under WARRENTY
:fume: Really Robert are you as a amazed at the amount of questions on how to fix a warranty vehicle. What do you people want, to come into the dealer with as much knowledge as someone who has been doing this for 20 years and is still challenged daily? Just take the d**n warranty work to the dealer and let us fix it. Warranty costs are worked into the $50k you paid for the vehicle.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
