Underbody Diesel Wash
anyone ever heard for guys in high road salt areas that some people spray the bottom of their trucks with diesel fuel ? I assume it is to clean or protect everthing on the underside. I heard just to soak it down and leave it. :)
I assume this would be as a barrier or protection layer... Maybe the oily layer fends off the salt or at least protects the truck from it?
No snow here so we don't have any such problems. :D
It won't help. I have once tried motoroil on a spot, just to see if it works or helps anything. It did not.
Hope this answeres your question.
BTW: You did not sound too respectful in your recent reply to one of my well ment posts. Get serious!
We used to use ATF and used motor oil back home. you soak it down with a shutz gun or similar spray gun that you don't care about. If you have an old paint gun, you can use that, but the mixture must be tinned out (we used diesel or furnace oil). You spray the under side on a nice hot day, let it soak in for about an hour, give it another light spray, than hit the nearest dusty gravel road. The dust sticks to the fresh oils and forms a protective layer. Repeated applications over the years results in a no-rust frame encased in about 1/2" of oily clay.
The biggest benefit is that the clay, unlike rubberized coatings, is able to breathe. If you have a spot where water gets under the rubber, its trapped where the clay just lets it escape.
This is not however the least bit environmentally friendly. Which is fine with me. :):D:fume:
Diesel would do a similar job, it would just end up being a lot runnier, and you would have to do repeated applications at a time to get any layer of protection. But it would creep into all the cracks crevices and seams like no ones business. Although your truck would smell of fuel for weeks.
Hey, 1999 Tahoe, I was only kidding with you. My :) just meant I agreed with you. I don t think the little cartoon is put on here to offend anyone. It s just a short way to say I agree.I ve been involved far too long on this and other auto websites and clubs to stoop so low as to argue or offend someone in this type of forum.
BTW: That s a clean looking Tahoe.
:D
Hey Mark... I would think diesel or oil would be bad for the rubber parts under the truck. I know oil breaks down rubber parts. Just a thought.
Hey, 1999 Tahoe, I was only kidding with you....
Alright then. No worries. :lol:
As to my winter test with "engine oil proofing" against salt, I tell you what I did and you'll be the judge.
When I was young I used my 2 years old dirtbike for everyday commute including in the winters of Germany. Trying to "winterpfoof" it, I started to "wintercoat" among others the swingarm of the bike with motoroil way before the winter. I applied it several times while I stopped washing the bike. At the same time, on the side of the chain, the chain kept on coating the swingarm the "natural" way, with excess chainlube.
In the spring I washed the bike and examined the results. In areas where the chainlube created a really thick gue things looked pretty good. However on the other side of the swingarm where "only" the several allplications of motoroil were "protecting" the picture did look much worse. I found several new rustspots even in areas otherwise more or less protected from direct spraywater. Welds seemed to have done worst.
The next winter I washed the bike with a brush almost every day after I got home. That seemed to actually work better.
I don't think a few minutes of sparying the underbody with water is enough to get the salt completely off. There always seems to be some residue left; and that still tastes salty (yes, for the love of my vehicles and to be sure, I have tried it)
Using a gentle brush would be optimal although probably impossible to use for the under carriage.
Then I decided the hell with all this winter and moved to California. :)
It's great having not to worry about road salt, but still, now I miss the winter. I think I'm going -> :D
thanks for the info, cause I d hate to do all that work and mess for a small possible gain.(and maybe damage the rubber parts, I never thought of that).I guess I ll just hose it down good after the winters and trade it in every 3 years. I like the fact you ll be willing to taste the water to see the results :D
The Diesel fuel sprayed on the underbody has to smell and a major dirt collector, sometimes after I know there will be no more snow and salt on the road ways I will go get the lawn sprinkler (the one that goes back and forth) and put it under the truck for about 15 minutes so it can flush the salt out.
You know what else works, doesn't damage rubber and is one of the better things to coat the undercarriage with. Krown undercoat. Or rust check.
the oil, diesel, whatever is the redneck rolling pennies for gas broke, solution to rust check. Rust check and similars usually run in the 100-200 dollar area to do, a quart of diesel, and some used oil costs like 2 bucks. Thats why people do it. It does work well, but can screw some stuff up good. But you will have a solid frame after years of use.
I guess there would be no bushings, rubber hoses, or anything else left...but there would be a nice solid frame... :D:lol::)
Not to hijack this thread; just to share some info:
Washington, Oregon, Idaho and BC do use a road salt substitute. Vehicles look pretty decent over there. Perhaps an issue to be raised with your elected local officials. Here is some ammunition:
This is a link to a 2001 report that was prepared by Colorado DOT:
Evaluation of Selected Deicers <- (http://ttap.colostate.edu/Library/CDOT/CDOT-DTD-R-2001-15.pdf)
It gets especially interesting around Page 101
And then I also found this on the net some time ago, but I don't know how recent this following info is:
I've never heard of using diesel fuel. In the UK, they use Waxoyl (wax oil). It seems to work fairly work. You can brew waxoyl yourself, but it is a mess!
Any more info on that road salt substitute 1999 Tahoe? That is very interesting. I wish all states were required to stop using real road salt.
Any more info on that road salt substitute 1999 Tahoe?...
That's pretty much all I got. We were considering to move to Oregon and that's how and why I researched the topic and found the info on road salt substitute (after moving from Germany to California, I just did not want to move any place anymore, that uses roadsalt).
My wife and I just got back from our Oregon househunting trip and all I can say is that IT SEEMS LIKE THE ROAD SALT SUBSTITUTE WORKS. Even old cars seem to be in excellent condition in Oregon. You basically do not see rusted cars. I looked at how towhitches of older Trucks hold up (simply painted steel) and it all looks pretty good. But I'm sure there are some guys here on this Forum from Oregon who can elaborate this better than I do.
It is worth to mention that these road salt substitutes are supposedly not only better for our vehicles, they are purportedly also better for road infrastucture like bridges and roadsigns etc. Additionally they seem to be better for the environment too.
So I think the issue is worth some efforts to make it a law.
Hey Andreas, are you originally from Germany, or some place else?
I grew up in Germany. In terms of cars/trucks, California is paradise, having not to deal with roadsalt here.
Still there can be quite some damage caused by the sun too; not to mention the too many uninsured or DUI CA-drivers.
Other than that California is a mechanics dream: bolts and nuts almost never seize.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 413 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
